I have on nvidia gforce GTX 860M on my laptop, and I just installed CUDA 7 with new driver. After installation I run deviceQuerry and it passed the test, alongside with the bandwidth test. All the other tests in Nvidia Samples are failing.
Another thing is that when I return my laptop from sleep, I cant run even deviceQuerry, it says no capable cuda device found. After rebooting i can again run deviceQuerry, but all the other tests fail again.
this is result of deviceQuerry
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 860M"
CUDA Driver Version / Runtime Version 7.0 / 7.0
CUDA Capability Major/Minor version number: 5.0
Total amount of global memory: 2048 MBytes (2147352576 bytes)
( 5) Multiprocessors, (128) CUDA Cores/MP: 640 CUDA Cores
GPU Max Clock rate: 1020 MHz (1.02 GHz)
Memory Clock rate: 2505 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 7.0, CUDA Runtime Version = 7.0, NumDevs = 1, Device0 = GeForce GTX 860M
Result = PASS
Even though it passes this test it is not able to run any of the sample codes.
after putting laptop to the sleep I get following message
./deviceQuery Starting...
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
these are some of the readings
lsmod | grep nvidia
nvidia_uvm 67139 0
nvidia 8370760 1 nvidia_uvm
drm 303102 8 i915,drm_kms_helper,nvidia
cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 346.46 Tue Feb 17 17:56:08 PST 2015
GCC version: gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1)
lspci | grep -i nvidia
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 860M] (rev ff)
ls -al /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 Apr 8 21:59 /dev/nvidia0
crw-rw-rw- 1 root root 195, 255 Apr 8 21:59 /dev/nvidiactl
crw-rw-rw- 1 root root 250, 0 Apr 8 21:59 /dev/nvidia-uvm
as well I get message after running nvidia-settings :
You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run nvidia-xconfig
as root), and restart the X server.
I did previously run nvidia-xconfig as root
