I’m trying to install cuda 8.0 using the cuda_8.0.61_375.26_linux.run file. I’ve followed the steps here: http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile but I’m getting several warnings/errors including one stating “You do not appear to have an NVIDIA GPU supported by the 375.26 NVIDIA Linux graphics driver installed in this system.”
My GPU is ASUS ROG GeForce GTX 1080 STRIX-GTX1080-A8G-GAMING. Per http://www.nvidia.com/Download/driverResults.aspx/112992/en-us, the GTX 1080 is listed as compatible with this NVIDIA Linux driver. I contacted ASUS to ask about compatibility but they said to contact NVIDIA.
I’d like confirmation that this ASUS GPU is compatible with the Cuda Linux toolkit and if so, any tips on resolving these install errors.
Machine:
Windows 10 Pro 64 bit
Cuda installation occurring in Virtualbox VM running Ubuntu 14.04 with kernel downgraded to 3.13.0-108.
Full install log below:
Using more to view the EULA.
Installing the NVIDIA display driver...
Verifying archive integrity... OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 375.26...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
WARNING: You do not appear to have an NVIDIA GPU supported by the 375.26
NVIDIA Linux graphics driver installed in this system. For
further details, please see the appendix SUPPORTED NVIDIA GRAPHICS
CHIPS in the README available on the Linux driver download page at
www.nvidia.com.
Welcome to the NVIDIA Software Installer for Unix/Linux
Detected 4 CPUs online; setting concurrency level to 4.
License accepted by command line option.
Installing NVIDIA driver version 375.26.
Running distribution scripts
Executing /usr/lib/nvidia/pre-install: [ ] 0%
Executing /usr/lib/nvidia/pre-install: [##############################] 100%
WARNING: One or more modprobe configuration files to disable Nouveau are
already present at:
/etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be
sure you have rebooted your system since these files were written.
If you have rebooted, then Nouveau may be enabled for other
reasons, such as being included in the system initial ramdisk or
in your X configuration file. Please consult the NVIDIA driver
README and your Linux distribution's documentation for details on
how to correctly disable the Nouveau kernel driver.
The distribution-provided pre-install script failed! Are you sure you want
to continue? (Answer: Continue installation)
For some distributions, Nouveau can be disabled by adding a file in the
modprobe configuration directory. Would you like nvidia-installer to
attempt to create this modprobe file for you? (Answer: Yes)
One or more modprobe configuration files to disable Nouveau have been
written. For some distributions, this may be sufficient to disable
Nouveau; other distributions may require modification of the initial
ramdisk. Please reboot your system and attempt NVIDIA driver installation
again. Note if you later wish to reenable Nouveau, you will need to delete
these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
Performing CC sanity check with CC="/usr/bin/cc".
Using the kernel source path '/usr/src/linux-headers-3.13.0-108-generic' as
specified by the '--kernel-source-path' commandline option.
Kernel source path: '/usr/src/linux-headers-3.13.0-108-generic'
Kernel output path: '/usr/src/linux-headers-3.13.0-108-generic'
Performing rivafb check.
Performing nvidiafb check.
Performing Xen check.
Performing PREEMPT_RT check.
Cleaning kernel module build directory.
Building kernel modules
: [ ] 0%
: [## ] 3%
: [### ] 7%
: [#### ] 11%
: [##### ] 15%
: [###### ] 20%
: [######## ] 23%
: [######### ] 28%
: [########## ] 31%
: [########### ] 36%
: [############ ] 40%
: [############## ] 43%
: [############### ] 47%
: [################ ] 51%
: [################# ] 56%
: [################## ] 60%
: [#################### ] 63%
: [##################### ] 68%
: [###################### ] 72%
: [####################### ] 75%
: [######################## ] 80%
: [########################## ] 83%
: [########################### ] 87%
: [############################ ] 92%
: [############################# ] 95%
ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most
frequently when this kernel module was built against the wrong or
improperly configured kernel sources, with a version of gcc that
differs from the one used to build the target kernel, or if a driver
such as rivafb, nvidiafb, or nouveau is present and prevents the
NVIDIA kernel module from obtaining ownership of the NVIDIA graphics
device(s), or no NVIDIA GPU installed in this system is supported by
this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel
messages' at the end of the file '/var/log/nvidia-installer.log' for
more information.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find
suggestions on fixing installation problems in the README available
on the Linux driver download page at www.nvidia.com.
Kernel module compilation complete.
Unable to determine if Secure Boot is enabled: No such file or directory
Kernel module load error: No such device
Kernel messages:
[ 9575.816589] type=1400 audit(1487969728.294:10): apparmor="STATUS"
operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd"
pid=560 comm="apparmor_parser"
[ 9575.843674] intel8x0: disable (unknown or VT-d) VM optimization
[ 9575.894423] init: failsafe main process (597) killed by TERM signal
[ 9575.983686] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9576.113525] intel8x0: white list rate for 1028:0177 is 48000
[ 9576.396852] random: nonblocking pool is initialized
[ 9576.541586] vboxsf: Successfully loaded version 5.1.14 (interface
0x00010004)
[ 9576.565953] init: plymouth-upstart-bridge main process ended, respawning
[ 9576.568505] init: plymouth-upstart-bridge main process (1029) terminated
with status 1
[ 9576.568511] init: plymouth-upstart-bridge main process ended, respawning
[ 9576.808951] VBoxService 5.1.14 r112924 (verbosity: 0) linux.amd64 (Jan
16 2017 17:38:46) release log
[ 9576.808951] 00:00:00.000058 main Log opened
2017-02-24T20:55:29.288062000Z
[ 9576.808979] 00:00:00.000110 main OS Product: Linux
[ 9576.808994] 00:00:00.000128 main OS Release: 3.13.0-108-generic
[ 9576.809007] 00:00:00.000141 main OS Version: #155-Ubuntu SMP Wed Jan
11 16:58:52 UTC 2017
[ 9576.809026] 00:00:00.000156 main Executable:
/opt/VBoxGuestAdditions-5.1.14/sbin/VBoxService
[ 9576.809026] 00:00:00.000156 main Process ID: 1126
[ 9576.809026] 00:00:00.000157 main Package type: LINUX_64BITS_GENERIC
[ 9576.809403] 00:00:00.000529 main 5.1.14 r112924 started. Verbose
level = 0
[ 9576.844783] init: plymouth-stop pre-start process (1178) terminated with
status 1
[ 9577.991325] e1000: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow
Control: RX
[ 9577.992119] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9709.273238] nvidia: module license 'NVIDIA' taints kernel.
[ 9709.273240] Disabling lock debugging due to kernel taint
[ 9709.278096] NVRM: No NVIDIA graphics adapter found!
The driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly.
If you know that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the '--kernel-source-path' flag.
= Summary =
Driver: Installation Failed
Toolkit: Installation skipped
Samples: Installation skipped
Logfile is /tmp/cuda_install_1423.log
cuda_install_1423.log (18.3 KB)
nvidia-installer.log (27.2 KB)
