AEE
1
I have a large and popular HP DL980 that currently runs CentOS 6. A while back we installed a K40c GPU and CUDA 7.5 and later 8.0.
We’ve recently gotten requests for software like TensorFlow, whose installation favors Ubuntu. I haven’t gotten TensorFlow working with CentOS 6.
Would it be reasonable to install things like TensorFlow inside an Ubuntu or debian virtual machine using KVM?
It’s not clear whether it’s a good idea to have the host OS be Ubuntu or debian.
Also, if I use debian instead of Ubuntu, should I expect Ubuntu GPU projects to work?
I have gotten tensorflow working on CentOS using instructions like what is here:
[url]http://www.nvidia.com/object/gpu-accelerated-applications-tensorflow-installation.html[/url]
You have to build many things from scratch, so its not a complete set of instructions, but a pretty good roadmap.
Another alternative would be to use docker containers:
[url]https://devblogs.nvidia.com/parallelforall/nvidia-docker-gpu-server-application-deployment-made-easy/[/url]
You can effectively have ubuntu running inside a docker container that is on CentOS.
Finally, yes, it should be possible to use a K40c on KVM in CentOS. This is not a perfectly exact set of instructions, but pretty close:
[url]https://github.com/dholt/kvm-gpu[/url]
