After installing in a Centos 7 the nvidia driver 384.59, in order to install CUDA 8 I have downloaded the corresponding rpm packages. The installation process downgrades the nvidia driver to the 375 version installing in addition dependencies as nvidia-kmod. Why? Should I give up and remove the 384.59 driver for the sake of compatibility with CUDA 8?
For us owners of the 1080 TI series and newer pascal GPUs: The driver version included with CUDA 8.0, 375.26 does not recognize these newer Nvidia products, which requires us to use newer driver versions up to 384.59. In an Ubuntu/Linux installation, overwriting the drivers may cause issues. There is a workaround by using the local runfile installation, which allows you to bypass the automatic install of 375 drivers. This is really kludgy.
Nvidia CUDA dev team - please update the 8.0 CUDA to current stable 384 version so Titan Xp and 1080Ti owners can have Use of CUDA without jumping through even more hoops? Thank you.
I’ve found this to be true of the GTX1060 as well. The version of NVIDIA drivers that you get is different from what cuda expects. As you can see, nvidia-modprobe is built for 375.26, while all the other packages use either 384.69 or 375.82.
dpkg -l | grep nvidia
ii bumblebee-nvidia 3.2.1-10 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver
ii nvidia-375 375.82-0ubuntu0~gpu16.04.1 amd64 NVIDIA binary driver - version 375.82
ii nvidia-375-dev 375.82-0ubuntu0~gpu16.04.1 amd64 NVIDIA binary Xorg driver development files
ii nvidia-modprobe 375.26-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-opencl-icd-375 375.82-0ubuntu0~gpu16.04.1 amd64 NVIDIA OpenCL ICD
rc nvidia-prime 0.8.2 amd64 Tools to enable NVIDIA's Prime
ii nvidia-settings 384.69-0ubuntu0~gpu16.04.1 amd64 Tool for configuring the NVIDIA graphics driver
I experience the same issue, on Ubuntu 16. After installing 384.69 stable driver version, the Cuda 8.0.61 installation automatically downgrades the driver to 375.66.
Is there any estimation about adding the new stable driver (384 version) to CUDA 8 ?
Note: I’ve since resolved my CUDA/Driver issues, so my earlier comment is mostly useful as a historical artifact, evidence of problems in my earlier setup.
