So im trying to use Tensorflow-GPU, and inorder to use it i have to use Cuda 9.0, as to my current knowledge there isnt a way to get it to work on Cuda 9.1 or 9.2
lolbozo@Jim-Jam:/usr/local/cuda/samples/bin/x86_64/linux/release$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
modprobe: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/4.4.0-17134-Microsoft/modules.builtin.bin'
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.0-17134-Microsoft/modules.dep.bin'
modprobe: ERROR: ../libkmod/libkmod-module.c:832 kmod_module_insert_module() could not find module by name='nvidia_384_uvm'
modprobe: ERROR: could not insert 'nvidia_384_uvm': Unknown symbol in module, or unknown parameter (see dmesg)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
lolbozo@Jim-Jam:/usr/local/cuda/samples/bin/x86_64/linux/release$ sudo ./deviceQuery
-> unknown error
Result = FAIL
The only 2 solutions I’ve been able to find are to run with sudo, and as you see that didn’t fix anything, or to do a full shutdown of my computer, which also didn’t help at all
How would i go about installing it correctly? my graphics card is the GeForce MX150
It says Win10 because im using the 16.04LTS version of Ubuntu that you can download through the windows store, but my OS is Win10
If you’re running linux on top of win10, you won’t be able to use CUDA within that, I don’t believe. It needs to be a baremetal install of linux.
You would go about installing it correctly by reading the linux install guide, loading a fresh copy of a supported linux OS on your machine (not within win10, but on baremetal) and get your installers from http://www.nvidia.com/getcuda and follow the linux install guide carefully:
