Hello everyone!
Can anyone please tell where can I find CUDA 9.0 standalone installation for Drive PX2? Or is it only come as a part of DriveInstall 5.0.5.0b package? If it does, can it be installed without flashing PX2?
Thank you,
Strahinja
Hello everyone!
Thank you,
Strahinja
Dear Spet0005,
It is not possible to install CUDA on DPX2 without flashing DPX2.
Is there any special reason for this request?
Hello SteveNV,
Thank you for your reply.
I tried to flash Tegra A, by following instructions https://docs.nvidia.com/drive/driveinstall_docs/index.html , but i keep getting stuck at the following:
car
car
root 5519 0.0 0.0 201236 3400 ? Ssl 10:40 0:00 /home/car/NVIDIA/Drive/5050bL_SDK/_installer/sudo_daemon -installer=5465 -d=/home/car/NVIDIA/Drive/5050bL_SDK/_installer/tmp
0
/home/car/NVIDIA/Drive/5050bL_SDK///_installer/run_command -c="/home/car/NVIDIA/Drive/5050bL_SDK//_installer/configure_minicom ttyUSB2 car minirc.v4l_device.a" -d=/home/car/NVIDIA/Drive/5050bL_SDK///_installer/tmp -l=/home/car/NVIDIA/Drive/5050bL_SDK///_installer/logs/configure_minicom_minirc.v4l_device.a.log
The user `car' is already a member of `dialout'.
root 5519 0.0 0.0 201236 3404 ? Ssl 10:40 0:00 /home/car/NVIDIA/Drive/5050bL_SDK/_installer/sudo_daemon -installer=5465 -d=/home/car/NVIDIA/Drive/5050bL_SDK/_installer/tmp
0
/home/car/NVIDIA/Drive/5050bL_SDK///_installer/run_command -c="/home/car/NVIDIA/Drive/5050bL_SDK//_installer/configure_minicom ttyUSB1 car minirc.drivepx2.aurix" -d=/home/car/NVIDIA/Drive/5050bL_SDK///_installer/tmp -l=/home/car/NVIDIA/Drive/5050bL_SDK///_installer/logs/configure_minicom_minirc.drivepx2.aurix.log
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB1, 10:37:58
Press CTRL-A Z for help on special keys
All the minicom terminals on PX2 was closed, USB debug cable and Ethernet cable with internet connection were plugged into both, host and PX2.
Can you give me any advice for solving this problem?
Thank you,
Strahinja
I manage to solve previous problem by following https://docs.nvidia.com/drive/nvvib_docs/index.html#page/NVIDIA%2520DRIVE%2520Linux%2520SDK%2520Development%2520Guide%2FFlashing%2Fflashing_lnx.html%23wwpID0E0AD0HA
