Hi all,
I’m planning to try deep learning on CentOS using cuda.
So I got a GPU from NVIDIA and installed it on my CentOS but
as soon as I installed cuda9.0, X window does not start.
I mean after I installed cuda9.0 on my console(X is off) I tried to
start X window with the command “startx”, it crushed
with a segmentation fault shown below.
I tried to recreate /etc/X11/xorg.conf with the command
“nvidia-xconfig -o xorg.conf --busid=PCI:1:0:0” but everything I tried failed so far.
Could anyone tell me how to fix it and how to use cuda9.0 on X.
My environment and the error message are listed below.
environment
OS: CentOS Linux release 7.5.1804 (Core)
CPU: Intel i5 2.8GHz (8th gen)
GPU: NVIDIA Geforce 1070
driver of GPU: NOT nouveau but the one from NDIVIA
error message(/var/log/Xorg.0.log)
[ 41.821] (II) Loading sub module “fb”
[ 41.821] (II) LoadModule: “fb”
[ 41.845] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 41.858] (II) Module fb: vendor=“X.Org Foundation”
[ 41.858] compiled for 1.19.5, module version = 1.0.0
[ 41.858] ABI class: X.Org ANSI C Emulation, version 0.4
[ 41.858] (II) Loading sub module “wfb”
[ 41.858] (II) LoadModule: “wfb”
[ 41.859] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 41.864] (II) Module wfb: vendor=“X.Org Foundation”
[ 41.864] compiled for 1.19.5, module version = 1.0.0
[ 41.864] ABI class: X.Org ANSI C Emulation, version 0.4
[ 41.864] (II) Loading sub module “ramdac”
[ 41.864] (II) LoadModule: “ramdac”
[ 41.864] (II) Module “ramdac” already built-in
[ 41.880] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 41.880] (==) NVIDIA(0): RGB weight 888
[ 41.880] (==) NVIDIA(0): Default visual is TrueColor
[ 41.880] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 41.881] () NVIDIA(0): Enabling 2D acceleration
[ 41.899] (EE)
[ 41.899] (EE) Backtrace:
[ 41.899] (EE) 0: /usr/bin/X (xorg_backtrace+0x55) [0x56458cd0a135]
[ 41.899] (EE) 1: /usr/bin/X (0x56458cb5c000+0x1b1ec9) [0x56458cd0dec9]
[ 41.899] (EE) 2: /lib64/libpthread.so.0 (0x7f1d21e19000+0xf6d0) [0x7f1d21e286d0]
[ 41.899] (EE)
[ 41.899] (EE) Segmentation fault at address 0x0
[ 41.899] (EE)
Fatal server error:
[ 41.899] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 41.899] (EE)
[ 41.899] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 41.899] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 41.899] (EE)
[ 41.900] (EE) Server terminated with error (1). Closing log file.
nvidia-bug-report.log.gz (896 KB)
