Hello, I noticed that the findgllib.mk in the compile samples resolved UBUNTU_PKG_NAME to -L/usr/lib/nvidia-387 instead of /usr/lib/nvidia-390.
I have no /usr/lib/nvidia-387 but yes /usr/lib/nvidia-390 so compile fails
I installed the local deb after having installed driver 390.48.
- which dpkg >dev/null 2>&1 && dpkg l ‘nvidia-*’ | grep ‘^ii’ | awk ‘{print $$2}’ | head -i shows both entries
ii nvidia-387 …
ii nvidia-387-dev
ii nvidia-390
ii nvidia-390-dev
but the driver version for all of those is 390.48-0ubuntu0-gpu16.04.3 ; on the -387 entries the description reads, Transitional package. - nvidia-smi displays the correct driver 390.48
I cannot sudo apt-get uninstall nvidia-387 because it will carry 390 as well as cuda9.1 with it. It seems everything is correct except the presence of those transition packages, but the mk script fails because of this.
What is the simplest, cleanest way to fix this.?
thanks.
