After installing cuda 9.1, cuda-repo-ubuntu1604-9-1-local_9.1.85-1_amd64.deb. I got error when installing libraries,
~/sw$ sudo apt install cuda-libraries-9-1
Reading package lists… Done
Building dependency tree
Reading state information… Done
cuda-libraries-9-1 is already the newest version (9.1.85-1).
You might want to run ‘apt-get -f install’ to correct these:
The following packages have unmet dependencies:
cuda-cudart-dev-9-1 : Depends: cuda-driver-dev-9-1 but it is not going to be installed
cuda-libraries-dev-9-1 : Depends: cuda-driver-dev-9-1 (>= 9.1.85) but it is not going to be installed
cuda-samples-9-1 : Depends: cuda-driver-dev-9-1 but it is not going to be installed
cuda-toolkit-9-1 : Depends: cuda-nvml-dev-9-1 (>= 9.1.85) but it is not going to be installed
cuda-visual-tools-9-1 : Depends: cuda-driver-dev-9-1 but it is not going to be installed
Depends: cuda-nvml-dev-9-1 but it is not going to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
~/sw$
I ran ‘apt-get -f install’ and got similar “Unmet dependencies” errors.
Then I tried to remove Cuda 9.1 and got similar errors, again.
~/sw$ sudo apt-get autoremove --purge cuda
~/sw$
could anyone help me before I have to reinstall Ubuntu?
thanks!
Steve
