I have installed CUDA 9.1 and cudnn 7.0.5 on my Ubuntu 16.04. It has a Titan Xp CUDA-compatible GPU, however I get the following error:
Error: no CUDA-capable device is detected
error_util.h:93
Aborting...
error_util.h:93
Aborting...
maybe you didn’t install correctly.
what does
nvidia-smi
return?
$ nvidia-smi
Sat Dec 23 18:27:48 2017
| NVIDIA-SMI 387.34 Driver Version: 387.34 |
| 0 TITAN Xp COLLEC... Off | 00000000:01:00.0 On | N/A |
| 23% 28C P8 10W / 250W | 115MiB / 12188MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1045 G /usr/lib/xorg/Xorg 87MiB |
| 0 1616 G compiz 25MiB |
after you installed CUDA 9.1, did you validate the install?
I have reinstalled the driver, cuda & cudnn and everything works now.
Thank you for your support!
