Cuda 9.2 on ubuntu 17.10 problem
On a new system, although I have installed cuda 9.2 on ubuntu 17.10, I am not able to run basic samples.
The compilation runs fine, but the matrixmul says
CUDA error at …/…/common/inc/helper_cuda.h:1147 code=30(cudaErrorUnknown) “cudaGetDeviceCount(&device_count)”
The bin/ and lib64/ are in the path.
Any thought?
broken driver install
No sign of broken installation
what is the output of:
dmesg |grep NVRM
and
lsmod |grep nouv
and
nvidia-smi
If you are on a laptop, you may need to figure out how to enable the dGPU, e.g. using nvidia-prime
[url]How am I supposed to use nvidia-prime? - Ask Ubuntu
Right. It turns out that nouveau was the bug.
root@orca2:~# lsmod |grep nouv
nouveau              1638400  13
mxm_wmi                16384  1 nouveau
video                  40960  1 nouveau
i2c_algo_bit           16384  1 nouveau
ttm                    94208  1 nouveau
drm_kms_helper        167936  1 nouveau
drm                   356352  15 nouveau,ttm,drm_kms_helper
wmi                    24576  3 wmi_bmof,mxm_wmi,nouveau
Before removing that, nvidia-smi said “NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.”
When I removed it using nomodeset in the kernel options, the nvidia-smi was fine and matrixmul was fine too.
Proper install instructions are contained in the linux install guide:
[url]Installation Guide Linux :: CUDA Toolkit Documentation
