I seem to have successfully installed cuda-9.2 (Please see output of nvcc -V and nvidia-smi below). I am using Nvidia driver version 396.37, which satisfies the requirement for cuda-9.2 (version >=390). I am using a Titan Xp with Ubuntu 16.04.4 LTS.
I have followed the Cuda Toolkit Documentation instructions for installation to the letter, but I am unable to successfully execute the make command at step 7.2.3.2 Compiling the Examples. The (rather lengthy) error message is provided below. I have no idea what is going wrong, I have ensured all permissions for the directory containing the sample code with sudo chmod 777 NVIDIA_CUDA-9.2_Samples. I have been trying for days to properly install cuda, and had a similar issue while installing cuDNN. If anyone can provide any insights I would be eternally grateful!
Checking cuda and driver installations:
marlena@millenium-falcon:~$ nvcc -V
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Tue_Jun_12_23:07:04_CDT_2018
Cuda compilation tools, release 9.2, V9.2.148
marlena@millenium-falcon:~$ nvidia-smi
Thu Jul 12 16:45:39 2018
| NVIDIA-SMI 396.37 Driver Version: 396.37 |
| 0 TITAN Xp Off | 00000000:26:00.0 On | N/A |
| 23% 34C P8 11W / 250W | 205MiB / 12194MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1122 G /usr/lib/xorg/Xorg 160MiB |
| 0 1919 G compiz 42MiB |
marlena@millenium-falcon:~$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 396.37 Tue Jun 12 13:47:27 PDT 2018
GCC version: gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)
Errors upon running make:
marlena@millenium-falcon:~/cuda_sample_code/NVIDIA_CUDA-9.2_Samples$ make
make[1]: Entering directory '/home/marlena/cuda_sample_code/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAddDrv'
/usr/local/cuda-9.2/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o vectorAddDrv.o -c vectorAddDrv.cpp
vectorAddDrv.cpp: In function ‘int getMaxGflopsDeviceId()’:
vectorAddDrv.cpp:144:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated [-Wdeprecated-declarations]
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_devic
vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’
#define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__)
In file included from vectorAddDrv.cpp:31:0:
/usr/local/cuda-9.2/bin/../targets/x86_64-linux/include/cuda.h:2531:36: note: declared here
__CUDA_DEPRECATED CUresult CUDAAPI cuDeviceComputeCapability(int *major, int *m
vectorAddDrv.cpp:144:81: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated [-Wdeprecated-declarations]
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device));
vectorAddDrv.cpp:165:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated [-Wdeprecated-declarations]
vectorAddDrv.cpp:165:81: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated [-Wdeprecated-declarations]
vectorAddDrv.cpp: In function ‘int main(int, char**)’:
vectorAddDrv.cpp:323:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated [-Wdeprecated-declarations]
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, devID));
vectorAddDrv.cpp:323:72: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated [-Wdeprecated-declarations]
Assembler messages:
Fatal error: can't create vectorAddDrv.o: Permission denied
Makefile:345: recipe for target 'vectorAddDrv.o' failed
make[1]: *** [vectorAddDrv.o] Error 1
make[1]: Leaving directory '/home/marlena/cuda_sample_code/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAddDrv'
Makefile:52: recipe for target '0_Simple/vectorAddDrv/Makefile.ph_build' failed
make: *** [0_Simple/vectorAddDrv/Makefile.ph_build] Error 2
