global void degson(char *old1,char *new1,float *deg,int N)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
if (idx<N) deg[0] =10;// (float)((0>(old1[idx]-new1[idx]))?(-(old1[idx]-new1[idx])): ((old1[idx]-new1[idx])))/(float)255;
//deg=(float)100 (*deg) / (float)(N);
//cuPrintf("—>%f\n",deg);
} here is the global i used
here is where i set cuda i m using it in a function for chaging pictures to find as percent but cuda cant return true value gpud is always stay with begining value.
char *eski,*yeni;
float *benim;
void SaveFrame(AVFrame *pFrame, int width, int height, int iFrame,int zz,int size,char *mm,char *nn,float *hihi) {
SaveFrame(pFrameRGB, pCodecCtx->width, pCodecCtx->height, i,pFrame->pict_type,sayac,eski,yeni,benim);
float *gpud=(float *)malloc(sizeof(float));
//float *deneme=(float *)malloc(sizeof(float));
*gpud=0;
cudaMalloc((void **) &eski, pCodecCtx->widthpCodecCtx->height3);
cudaMalloc((void **) ¥i, pCodecCtx->widthpCodecCtx->height3);
cudaMalloc((void **)&benim, sizeof(float));
///////////////////gpu//////////////////////////////////////
cudaMemcpy(mm, old, widthheight3, cudaMemcpyHostToDevice);
cudaMemcpy(nn, pFrame->data[0],widthheight3, cudaMemcpyHostToDevice);
cudaMemcpy(hihi, gpud,sizeof(float), cudaMemcpyHostToDevice);
int block_size = 5;
int n_blocks = (widthheight3)/block_size + ((widthheight3)%block_size == 0 ? 0:1);
degson <<< n_blocks, block_size >>> (mm,nn,hihi,widthheight3);
if(cudaSuccess!=cudaMemcpy(gpud, hihi, sizeof(float), cudaMemcpyDeviceToHost)) puts(“patladı”);
printf("---->%f\n",gpud); getchar();
memcpy(old,pFrame->data[0],heightwidth*3);
gpud always 0 i wonder how i get true value thanks.
