What I would do is let each thread take care of a pixel in the output image. So it then has to go look in the input-image for all the values to add up. I would access the input image by means of a 2D-texture.
So let’s say you take a blocksize of 16*16, then your grid becomes (output_x_size/16), (output_y_size/16).
Won’t this mean reading each pixel of the input image a thousand times and cause horrible BW stall?
I wrote a version that runs on blocks of input image pixels coordinated with Rho values, say you have a 180 possible Rho values, you run a 1x180 thread block size with (imageWidth/180, imageHeight) grid size, thus I read just 1 time each pixel move this into shared memory and then run on the shared memory and each thread updates the hough plane for it’s designated Rho value. This offers a measly 2 times speedup relative to a CPU OpenMP version, on similar Rho and Theta definition. This runs slow because I’m accessing the global memory output hough plane for each rhoXpixel and this is both horrible and incurable, I could have put the whole hough image in shared memory and then add up but this would require too large a shared memory size. Don’t really know what to try, build a sparse image output.
I looked for any implementation code but found nothing, there’s an OpenVidia GPGPU implemntation which I don’t really get, there’s a cuvi lib with hough implementation but I’m getting no response and there’s no benchmarks yet. I also hear the next NPP will contain a Hough implemntation. I would really rather write it myself so I get control as I need a somewhat specialized version (a,b instead of Rho, Theta). Let me know if there’s anything?
