Hello again,
I was implementing a raytracer using CUDA ( just primary rays ). My scenes contain between 1M-6M of polygons ( static scene ).
How would you set your rays / data?
Rays as kernel data. Mesh triangle set as a read-only texture.
Mesh triangles as kernel , rays as read-only texture. This can be considered as a brute force approach. Just test one triangle vs all the rays. Then send results back to CPU and sort closestHit, etc…
What would you think is better?
- Use stackless spatial structures.
- Use brute-force data streaming.
What are your experiences with CUDA and raytracing?
And a question… does Gelato use CUDA to make raytracing? How is raytracing done there?
thx!
