Cuda and Tensorflow for SLES 15
Description
I am stuggling to set up TensorFLow on a SLES 15.3 Server, what I mean by that is: It does not detect the GPU.
What I thought to do is:
  1. Install Nvidia Graphics Card & Drivers (you probably already have)
  2. Download & Install CUDA
  3. Download & Install cuDNN
  4. Verify by simple program
What I am not figuring out is:
where can I find the cuDNN for SUSE linux, how do I know what is compatible with what?
I do have the newest Nvidia Drivers installed the rest I am now planing to start from scratch with CUDA cuDNN. The installed CUDA Version is 12.4 is the correct one?
Environment
TensorRT Version:
GPU Type: Nvidia A2
Nvidia Driver Version: 550.54.14
CUDA Version: 12.4
CUDNN Version:
Operating System + Version: SUSE Linux Enterprise Server 15 SP3
Python Version (if applicable): 3.10.13
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Hi @retusrieben ,
Please raise your issue here
I will but this is not answering my main question about where I find out if my config is in the first place compatible.
I am talking of the CUDA version, the GPU Driver and cUDNN and so on.
I do not believe it has something to do with tensorflow but the on the NVIDIA side since PyTorch is also not working.
So I reinstalled the Drivers and also CUDA.
if I run ./deviceQuery
I get the following output:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 100
→ no CUDA-capable device is detected
Result = FAIL
