Currently I do C++ development using MSVC 2008 on a Windows 7 64-bit Virtual Machine running under Oracle Sun Virtualbox. The host machine also happens to be running Windows 7 64-bit.
Is there any way to run CUDA code from the virtual machine? If that is not possible then can I at least compile the code on the Virtual Machine and then run it on the host, or does the nvcc compiler need access to the GPU card for information? Also, can the CUDA code be ran in emulation mode on the Guest VM? It would be nice if I could compile, debug in emulation mode, on the VM and then later run the non emulation version on the host.
I am quite sure that CUDA cannot be use in a VirtualBox (on my linux VirtualBox on Windows it’s not).
You can compile code gpu code for another computer you just have to know the compute capability of your CUDA device and specify it with nvcc -arch sm_xx where xx is your GPU capability (10 for 1.0, 11 for 1.1 …)
Emulation mode is still available but deprecated.
nvcc --device-emulation
NOTE: device emulation mode is deprecated in this release
and will be removed in a future release.
Nexus tools allows you to debug your GPU code but not in a VM.
