I have experienced a lot of errors with CUDA applications on Windows after installing 465.42 and 456.51 which came with Windows version 21313. On WSL side I have had no problems. CUDA applications work using official drivers (461.40).
According to event logs the driver crashes and gives following error:
The description for Event ID 13 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
Graphics Exception: ESR 0x407020=0x100 0x407028=0x0 0x40702c=0xf850f 0x407030=0x7The system cannot find message text for message number 0x%1 in the message file for %2
Here’s another one:
\Device\Video3
Graphics Exception: SKEDCHECK36_DEPENDENCE_COUNTER_UNDERFLOW failedThe system cannot find message text for message number 0x%1 in the message file for %2
