__CUDA_ARCH__ is not defined
While compiling on the Orin, I get this error:
In file included from /usr/local/cuda-11.4/include/cublas_v2.h:65:
In file included from /usr/local/cuda-11.4/include/cublas_api.h:76:
In file included from /usr/local/cuda-11.4/include/cuda_bf16.h:3584:
/usr/local/cuda-11.4/include/cuda_bf16.hpp:428:5: error: '__CUDA_ARCH__' is not defined, evaluates to 0 [-Werror,-Wundef]
#if __CUDA_ARCH__ >= 800
CUDA_ARCH is not defined for host compilation, and other posts explain that is better to check if CUDA_ARCH is defined before using it. Since this is a cuda header, could this fix be applied there too?
Thank you,
Could you share a source that can reproduce this issue?
Is this can be reproduced with the default CUDA sample directly?
