CUDA build error
Hello all,
I am new to CUDA. I am trying to run my first CUDA code.
This is what I have:
  1. I use VS2015 and I have installed the CUDA SDK.
  2. I included the following include and library directories in VS project settings:
    C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include
    C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\lib\x64
  3. In build customization, I have ticked ‘CUDA 8.0(.targets,.props)’
When I build a simple code I get:
Syntax error: ‘<’.
This is coming from the kernel call: Square<<<1,64>>>(d_out,d_in);
Provide the full error output from VS. What is the filename of the file you are compiling?
Also, this may not be actually a build error but an intellisense error.
The file name is CudaTest.cpp.
Does it have to be CudaTest.cu ?
The error (Build Only):
C2059 syntax error: ‘<’
It is coming from
Square<<<1,ARRAY_SIZE>>>(d_out,d_in);
yes it should be .cu
take a look at any of the cuda sample projects
I changed it to .cu. I am still getting the same error.
You need to not just change the file extension to .cu but you have to create a new CUDA C/C++ source module in your VS project. When you do that, it will automatically have a file extension of .cu and it will use nvcc to compile.
To repeat my suggestion again, take a look at any of the cuda sample projects.
Thanks!. That worked.
