CUDA By Example Questions Questions or troubles regarding examples in the book CUDA By Example.
arg. I hope the error message is enough. But probably not.
In the book, section 11.3, the example code fails to compile.
Basically, I don’t understand why the given definition for CUT_THREADROUTINE didn’t work.
#include <windows.h>
typedef HANDLE CUTThread;
//typedef unsigned (WINAPI *CUT_THREADROUTINE)(void *);   // causes quoted error
//typedef void *(WINAPI *CUT_THREADROUTINE)(void *);      // causes quoted error
typedef void *(*CUT_THREADROUTINE)(void *);               // compiles
#define CUT_THREADPROC unsigned WINAPI
#define  CUT_THREADEND return 0
//Create thread
CUTThread start_thread( CUT_THREADROUTINE func, void *data ) {
	return CreateThread(NULL, 0, (LPTHREAD_START_ROUTINE)func, data, 0, NULL);
You can’t mess with calling convention like that! Create Thread expects WINAPI calling convention, passing anything else (which is __cdecl by default) will corrupt the stack. There is probably a simple to fix mistake in that code, but I can’t help you without seeing it.
I’m also interested in finding out how to solve this problem.
Send me the code, then I’d have a look.
We were able to fix this by changing the definition of the function “routine”
  • to: unsigned WINAPI routine( void *pvoidData ) {…}
This worked for me, thanks!
