Cuda calls in DllMain
Hey,
I am building a Dll written using CUDA in the Visual Studio environment. I want to pre-allocate some CUDA memory when the DLL is loaded, and clean them up when the DLL is detached. Here is a sample DllMain call :
BOOL APIENTRY DllMain( HMODULE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
	switch (ul_reason_for_call)
	case DLL_PROCESS_ATTACH:
		//do cuda memory allocation here
		break;
	case DLL_THREAD_ATTACH:
		break;
	case DLL_THREAD_DETACH:
		break;
	case DLL_PROCESS_DETACH:
		//do cuda memory deallocation here
		break;
	return TRUE;
I tried adding the memory allocate and deallocate calls in DllMain. But my application crashes, and it crashes when it tries to do any allocation at DLL_PROCESS_ATTACH, or deallocate at DLL_PROCESS_DETACH.
Can some one help me understand what might be the issue here?
Goutham
http://www.lenholgate.com/blog/2004/09/why-does-windows-hold-the-loader-lock-whilst-calling-dllmain.html
do I know this one for sure? nope, but I wouldn’t bet against this
How are you attempting to allocate the memory? Using the driver or runtime API?
I’ll second tmurray on this; there’s a good chance it’s an issue with the loader lock. Unless absolutely necessary, you should avoid making API calls from within DllMain because there are all kinds of semantic edge-cases which can cause problems. Raymond Chen’s blog (see below) is a good source of info on stuff like this:
http://blogs.msdn.com/b/oldnewthing/archive/2004/01/27/63401.aspx
http://blogs.msdn.com/b/oldnewthing/archive/2007/09/04/4731478.aspx
Some info from Microsoft on interactions in DllMain:
http://msdn.microsoft.com/en-us/windows/hardware/gg487379.aspx
Thanks for replying!
Any suggestions for how I can load memory at start up. And then delete/deallocate towards the end!
