I run the TensorRT5.0.2 with multithreading, and after running for a while, the process will crash. The log is below:
[CHECK_FAILED] [/wangyusong/net_rt/caffe_compact_gpu/src/caffe/util/math_functions.cu] [89] (error) == (cudaSuccess) an illegal memory access was encounteredCUDA cask failure at execution for trt_volta_scudnn_128x64_relu_xregs_large_nn_v1.
cuda/caskConvolutionLayer.cpp (256) - Cuda Error in execute: 77
[ERR][05/05-23:15:19]FATAL ERROR, BACKTRACE NOT AVAILABLE
Is any idea about this?
Environment
TensorRT Version: TensorRT 5.0.2 GPU Type: Tesla T4 Nvidia Driver Version: 450.80.02 CUDA Version: CUDA10.0 CUDNN Version: 7.3.1 Operating System + Version: Ubuntu16.04 Python Version (if applicable): C++ instead TensorFlow Version (if applicable): No PyTorch Version (if applicable): No Baremetal or Container (if container which image + tag): No
Relevant Files
None
Steps To Reproduce
The code is not mine, I just want to ask for some advice.
Thanks for your reply,it will be better to give me some potential reasons for that error,because I am not a direct user of TensorRT,but the library I am depend on contains this problem,the stacktrace is below:
Looks like you’re using a very old version of the TensorRT. We recommend you please use the latest version of the TensoRT 8.4. https://developer.nvidia.com/nvidia-tensorrt-8x-download
If you still face this issue, please share with issue repro ONNX model and minimal script to try from our end for better debugging.
Well, updating TensorRT is a solution we are also advancing;or I put another way, what is the reason of this error, how can I reproduce this error with 100% probability?
I am loading, inferring, and releasing the model through multithreading and TensorRT, is there any problem? Sorry, I really need a direction to debug?
It’s another coredump below:
UFF and Caffe Parser have been deprecated from TensorRT 7 onwards, hence request you to try the ONNX parser.
