CUDA: copyout Memcpy FAILED: 4(unspecified launch failure)
Hi all,
When running a CUDA fortran test I had the following error:
0: copyout Memcpy (host=0x7fdb27b674c0, dev=0xb00300000, size=1053928) FAILED: 4(unspecified launch failure)
Here is my code:
module declare
   implicit none
   integer fanum,falen,nfa,maxfalen,n
   integer,allocatable,dimension(:)::afilen
   integer,allocatable,dimension(:,:)::afil
   double precision k_a,l_a
   double precision,allocatable,dimension(:)::xfa,yfa,zfa
   double precision,allocatable,dimension(:)::fxbondfa,fybondfa,fzbondfa
   real,allocatable,dimension(:)::fxw,fyw,fzw
   double precision zero
!  for device:
   double precision,allocatable,device::fxbondfa_d(:),fybondfa_d(:),fzbondfa_d(:)
   double precision,allocatable,device::fxanglfa_d(:),fyanglfa_d(:),fzanglfa_d(:)
   double precision,allocatable,device::xfa_d(:),yfa_d(:),zfa_d(:)
   integer,allocatable,device::afilen_d(:),atyp_d(:),afil_d(:,:)
   integer istat
end module
program test
use declare
use cudafor
use dev
implicit none
   k_a=1000.0d0 ! unit = 1e-20 J/nm**2
   l_a=5.4d0    !
   call getinfo(fanum,maxfalen,nfa)
   allocate(xfa(nfa),yfa(nfa),zfa(nfa),afil(maxfalen,fanum),afilen(fanum))
   call ringin(fanum,maxfalen,afil,afilen,nfa,xfa,yfa,zfa)
   allocate(fxbondfa(nfa),fybondfa(nfa),fzbondfa(nfa))
      allocate(fxw(nfa),fyw(nfa),fzw(nfa))
      allocate(fxbondfa_d(nfa),fybondfa_d(nfa),fzbondfa_d(nfa))
      allocate(xfa_d(nfa),yfa_d(nfa),zfa_d(nfa))
      xfa_d=xfa; yfa_d=yfa; zfa_d=zfa
      allocate(afil_d(maxfalen,fanum),afilen_d(fanum))
      do n=1,fanum
         afil_d(:,n)=afil(:,n)
      end do
      afilen_d=afilen
   istat = cudaSetDevice(0)
   zero=0.0d0
      call force_d<<<(fanum-1)/512+1,512>>>(fxbondfa_d,fybondfa_d,fzbondfa_d,fanum, &
           afil_d,afilen_d,xfa_d,yfa_d,zfa_d,k_a,l_a,zero)
      fxw=fxbondfa_d
      fyw=fybondfa_d
      fzw=fzbondfa_d
end
module dev
contains
   subroutine getinfo(fanum,maxfalen,nfa)
   implicit none
   integer fanum,maxfalen,nfa
   character (len=64) fileconf,chara
      fileconf='rconf000.inp'
   open(1,file=fileconf)
3  read(1,*)chara
   if(chara(1:4)/='FACT')then
      goto 3
   end if
   read(1,*)nfa,fanum,maxfalen
   close(1)
   end subroutine
   subroutine ringin(fanum,maxfalen,afil,afilen,nfa,xfa,yfa,zfa)
   implicit none
   integer,value::fanum,nfa
   integer,value::maxfalen
   integer n
   character (len=64) filecoor,fileconf,chara
      filecoor='rcoor000.inp'
!  read coordinates
   open(1,file=filecoor,form='unformatted')
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)
   read(1)xfa(1:nfa)
   read(1)yfa(1:nfa)
   read(1)zfa(1:nfa)
   close(1)
3  read(1,*)chara
      goto 3
   end if
   read(1,*)
   read(1,*)
   read(1,*)
   read(1,*)
   read(1,*)
   do n=1,fanum
      read(1,*)afilen(n),afil(1:afilen(n),n)
   enddo
   close(1)
   end subroutine
attributes(global) &
   subroutine force_d(fxbond,fybond,fzbond,fanum, &
                 afil,afilen,xfa,yfa,zfa,k_a,l_a,zero)
   implicit none
   integer,value:: fanum
   integer nf,jf,n0,n1,n2,n3,tid,bid
   integer,device::afilen(:)
   integer,device::afil(:,:)
   double precision,value::k_a,l_a,zero
   double precision dx,dy,dz,dx1,dy1,dz1,invdist,f,dist1,fx,fy,fz
   double precision,device::xfa(:),yfa(:),zfa(:)
   double precision,device::fxbond(:),fybond(:),fzbond(:)
tid=threadidx%x
bid=blockidx%x
   n1=afil(1,nf)
   fxbond(n1)=0.0d0
   fybond(n1)=0.0d0
   fzbond(n1)=0.0d0
      do jf=2,afilen(nf)
         n2=afil(jf,nf)
         n1=afil(jf-1,nf)
         dx1=xfa(n1)-xfa(n2)
         dy1=yfa(n1)-yfa(n2)
         dz1=zfa(n1)-zfa(n2)
         dist1=sqrt(dx1*dx1+dy1*dy1+dz1*dz1)
         invdist=1.0d0/dist1
         f=k_a*(dist1-l_a)
         fx=f*dx1*invdist
         fy=f*dy1*invdist
         fz=f*dz1*invdist
         fxbond(n1)=fxbond(n1)-fx
         fybond(n1)=fybond(n1)-fy
         fzbond(n1)=fzbond(n1)-fz
         fxbond(n2)=fx
         fybond(n2)=fy
         fzbond(n2)=fz
      end do
   end subroutine
end module
Can someone please tell me what I did wrong?
There are 2 input files, but I don’t see where I can attach them here.
Thanks,
Lam
Hi Lam,
You have an un-initialized variable “nf” being used as an index.
Hope this helps,
Mat
