[CUDA - CUBLAS] Deviation of computation results increase when calculating larger data
I guess that there are many developers using CUDA/CUBLAS for computational works. I have noticed that computing on small set of data with CUDA/CUBLAS providing the same result as we simple CPU program does (of course with higher speed). However, when the size of data set is growing (more computation, larger value of result) the difference between results from CUDA/CUPLAS program and CPU one is increasing. For example, just make a small test with matrix matrix multiplication.
// -*- C++ -*-
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include <cutil.h>
#include <cublas.h>
void mprintf(float* data,int rows,int cols,char* name){
  printf("Matrix : %s:\n",name);
  for(int i=0;i<rows;i++){
    for(int j=0;j<cols;j++){
      printf("%f ",data[j*rows+i]);
    printf("\n");
int main(void){
    float * h_A, *h_B, *h_C;
    float * d_A, *d_B, *d_C;
int wA = 3000;
    int hA = 3000;
    int wB = 1000;
    int hB = wA;
    int wC = wB;
    int hC = hA;
h_A = (float*)malloc(wA*hA*sizeof(float));
    h_B = (float*)malloc(wB*hB*sizeof(float));
    h_C = (float*)malloc(wC*hC*sizeof(float));
// Allocation des structures
    for (int i = 0; i < wA*hA; i++){
      h_A[i] = (float)rand()/(float)RAND_MAX;
    for (int i = 0; i < wB*hB; i++){
      h_B[i] = (float)rand()/(float)RAND_MAX;
   for (int i = 0; i < wC*hC; i++){ //not necessary
      h_C[i] = 0.0;
cublasStatus status;
    status = cublasInit();
    if (status != CUBLAS_STATUS_SUCCESS) {
      fprintf (stderr, "!!!! CUBLAS initialization error\n");
      return EXIT_FAILURE;
status = cublasAlloc(wA*hA, sizeof(d_A[0]), (void**)&d_A);
    status = cublasAlloc(wB*hB, sizeof(d_B[0]), (void**)&d_B);
    status = cublasAlloc(wC*hC, sizeof(d_C[0]), (void**)&d_C);
cublasSetMatrix( hA, wA, sizeof(float), h_A, hA, d_A, hA);
    cublasSetMatrix( hB, wB, sizeof(float), h_B, hB, d_B, hB);
float alpha = 1.0;
    float beta = 0.0;
//    cublasSgemm('t', 'n', L, K, N, alpha, d_A, N, d_B, N, beta, d_C, N);
    cublasSgemm('N', 'N', hA, wB, hB, alpha, d_A, hA, d_B, hB, beta, d_C, hC);
    status = cublasGetError();
      fprintf (stderr, "!!!! kernel execution error.\n");
status = cublasGetVector(wC*hC, sizeof(h_C[0]), d_C, 1, h_C, 1);
    // CPU computation
    float* h_CPU = (float*)malloc(wC*hC*sizeof(float));
     for (int l = 0; l < hC; l++){
       for(int k=0; k < wC; k++){
         float sum = 0.0;
         for(int n=0;n < wA;n++) sum+= h_A[n*hA+l]*h_B[k*hB+n];
         h_CPU[k*hC+l] = sum;
    CUTBoolean res = cutCompareL2fe(h_C, h_CPU,wC*hC, 1e-6f);
    printf("Test %s \n", (1 == res) ? "PASSED":"FAILED");
status = cublasFree(d_A);
    status = cublasFree(d_B);
    status = cublasFree(d_C);
free(h_A);
    free(h_B);
    free(h_C);
    status = cublasShutdown();
    return 1;
The code above pass its testing with matrices size A(3000x3000) B(1000x3000) (colxrow), however, if we make just wA to be more than 4500 (no matter how big of hA,wB are) the test will be failed.
At first I thought it is problem of CUBLAS, then I try to make my CUDA program and it provides the same result as CUBLAS one.
Can anyone help me out of this issue?
Thank you very much,
IZ
Check out this whitepaper: http://developer.nvidia.com/content/everything-you-ever-wanted-know-about-floating-point-were-afraid-ask
In floating-point computation in general, numerical error accumulates on both CPUs and GPUs, but not necessarily in the same way. The larger, or more ill-conditioned a problem, the larger the amount of accumulated error. Thus, simply trying to match the results on one platform to those on another is unlikely to indicate correctness, or the amount of error (absolute or relative) incurred on either platform. A recommended methodology is to compare results from either platform to a higher-precision reference implementation.
Thanks njuffa,
That’s exactly what I want to know. The making of difference in floating point calculation between CPU and GPU.
Your post helps indeed.
