CUDA cuLibraryGetUnifiedFunction missing example to show how to use those api
I am studying cuda library management api on RTX 5060 Ti with CUDA 12.9 on Windows
I write an device.cu, use nvcc -rdc=true -cubin device.cu -o device.cubin
And then I write an main.cu, which use the follow api:
  • cuLibraryLoadFromFile to get theCUlibrary
  • cuLibraryGetKernel to get the CUkernel
  • cuLibraryGetUnifiedFunction to get the function ptr void **
But I just can’t run cuLibraryGetUnifiedFunction, is there any example or document to show how to use get unified function?
Here is the device.cu:
#include <cuda.h>
extern "C" __device__ void device_func_add(int* data, int n) {
    int i = blockIdx.x * blockDim.x + threadIdx.x;
    if(i < n){
        data[i] += 1;
extern "C" __device__ void device_func_sub(int* data, int n) {
    if(i < n){
        data[i] -= 1;
__device__ void (*g_fn_add)(int* data, int n) = device_func_add;
__device__ void (*g_fn_sub)(int* data, int n) = device_func_sub;
extern "C" __global__
void elementWise(void (*func)(int*, int), int* data, int n)
    func(data, n);
Here is the main.cu:
#include <cuda.h>
#include <cstdio>
#include <cstdlib>
#include <iostream>
namespace {
constexpr int kNumElements = 256;
// Driver API returns CUresult instead of cudaError_t, and there is no
// cudaGetErrorString(); resolve both the symbolic name and the message.
void reportError(const char* expr, CUresult rc) {
  const char* name = nullptr;
  const char* str = nullptr;
  cuGetErrorName(rc, &name);
  cuGetErrorString(rc, &str);
  std::cerr << expr << " failed: " << (name ? name : "?") << " ("
            << (str ? str : "?") << ")" << std::endl;
#define CU_CHECK(expr) \
  do { \
    CUresult _rc = (expr); \
    if (_rc != CUDA_SUCCESS) { \
      reportError(#expr, _rc); \
      std::exit(EXIT_FAILURE); \
  } while (false)
// Matches the device-side signature of device_func_add / device_func_sub.
using DeviceFuncPtr = void (*)(int*, int);
} // namespace
int main() {
  CU_CHECK(cuInit(0));
  int deviceCount = 0;
  CU_CHECK(cuDeviceGetCount(&deviceCount));
  if (deviceCount == 0) {
    std::cerr << "No CUDA-capable device found." << std::endl;
    return EXIT_FAILURE;
  CUdevice device;
  CU_CHECK(cuDeviceGet(&device, 0));
  char deviceName[256] = {};
  CU_CHECK(cuDeviceGetName(deviceName, sizeof(deviceName), device));
  int unifiedAddressing = 0;
  CU_CHECK(cuDeviceGetAttribute(
      &unifiedAddressing, CU_DEVICE_ATTRIBUTE_UNIFIED_ADDRESSING, device));
  int unifiedFunctionPointers = 0;
      &unifiedFunctionPointers,
      CU_DEVICE_ATTRIBUTE_UNIFIED_FUNCTION_POINTERS, device));
  std::cout << "Device: " << deviceName << "\n"
            << "  unified addressing:       " << unifiedAddressing << "\n"
            << "  unified function pointers: " << unifiedFunctionPointers
            << std::endl;
  if (!unifiedFunctionPointers) {
    std::cerr << "Device does not support unified function pointers."
              << std::endl;
  // cuInit() does NOT create a context. The driver API needs a current
  // context for allocations, copies and kernel launches.
  CUcontext context;
  CU_CHECK(cuDevicePrimaryCtxRetain(&context, device));
  CU_CHECK(cuCtxSetCurrent(context));
  // Context-less library load: kernels are addressed by name, not by a
  // module + function handle.
  CUlibrary library;
  CU_CHECK(cuLibraryLoadFromFile(&library, "device.cubin",
                                 nullptr, nullptr, 0,
                                 nullptr, nullptr, 0));
  std::cout << "Loaded device.cubin" << std::endl;
  // Unified function pointer: a host-callable pointer to a __device__
  // function, usable as a kernel argument.
  DeviceFuncPtr deviceFunc = nullptr;
  CUresult rc = cuLibraryGetUnifiedFunction(
      reinterpret_cast<void**>(&deviceFunc), library, "device_func_add");
  if (rc != CUDA_SUCCESS) {
    std::cout.flush();
    reportError("cuLibraryGetUnifiedFunction(\"device_func_add\")", rc);
  } else {
    std::cout << "Resolved unified function 'device_func_add'" << std::endl;
  CUkernel kernel;
  CU_CHECK(cuLibraryGetKernel(&kernel, library, "elementWise"));
  std::cout << "Resolved kernel \"elementWise\"" << std::endl;
  int hostIn[kNumElements];
  int hostOut[kNumElements];
  for (int i = 0; i < kNumElements; ++i) {
    hostIn[i] = i;
    hostOut[i] = -1;
  CUdeviceptr deviceData = 0;
  CU_CHECK(cuMemAlloc(&deviceData, kNumElements * sizeof(int)));
  CU_CHECK(cuMemcpyHtoD(deviceData, hostIn, kNumElements * sizeof(int)));
  // Round-trip the buffer so the allocation/copy path is verified even when
  // the launch cannot run.
  CU_CHECK(cuMemcpyDtoH(hostOut, deviceData, kNumElements * sizeof(int)));
  bool copyOk = true;
    if (hostOut[i] != hostIn[i]) {
      copyOk = false;
      break;
  std::cout << "Host->device->host round trip: "
            << (copyOk ? "OK" : "MISMATCH") << std::endl;
  bool launchOk = false;
  if (deviceFunc != nullptr) {
    // Kernel parameters are passed as an array of pointers to the
    // arguments. 'n' must be a real lvalue: the driver reads sizeof(int)
    // bytes from the address it is given.
    int n = kNumElements;
    void* kernelArgs[] = {
        static_cast<void*>(&deviceFunc),  // void (*)(int*, int)
        static_cast<void*>(&deviceData),  // int*
        static_cast<void*>(&n),           // int
    // dim3 is a runtime-API type and is unavailable here, so the launch
    // geometry is passed as plain unsigned ints. A CUKernel is launched
    // by casting it to CUfunction.
    CU_CHECK(cuLaunchKernel(reinterpret_cast<CUfunction>(kernel),
                            1, 1, 1,            // gridDim x/y/z
                            kNumElements, 1, 1, // blockDim x/y/z
                            0, nullptr,         // sharedMemBytes, stream
                            kernelArgs, nullptr));
    CU_CHECK(cuCtxSynchronize());
    int mismatches = 0;
      if (hostOut[i] != hostIn[i] + 1) {
        ++mismatches;
    launchOk = (mismatches == 0);
    std::cout << "data[0..3]: ";
    for (int i = 0; i < 4; ++i) {
      std::cout << hostOut[i] << (i == 3 ? "" : ", ");
    std::cout << "  (expected " << hostIn[0] + 1 << ", " << hostIn[1] + 1
              << ", " << hostIn[2] + 1 << ", " << hostIn[3] + 1 << ")\n"
              << "data[" << kNumElements - 1 << "]: "
              << hostOut[kNumElements - 1] << "  (expected "
              << hostIn[kNumElements - 1] + 1 << ")" << std::endl;
    if (launchOk) {
      std::cout << "All " << kNumElements
                << " elements incremented correctly" << std::endl;
    } else {
      std::cerr << mismatches << " / " << kNumElements
                << " elements are wrong" << std::endl;
  CU_CHECK(cuMemFree(deviceData));
  CU_CHECK(cuLibraryUnload(library));
  CU_CHECK(cuDevicePrimaryCtxRelease(device));
  if (!copyOk) {
  if (deviceFunc == nullptr) {
    // Distinct code: the driver-API path is fine, the cubin lacks a UFT.
    return 2;
  return launchOk ? EXIT_SUCCESS : EXIT_FAILURE;
Here is the running log:
PS D:\Users\xxx\WorkSpace\libmanagement> cuobjdump.exe -symbols .\device.cubin
symbols:
STT_OBJECT  STB_WEAK  STV_DEFAULT U __UDT_OFFSET
STT_OBJECT  STB_WEAK  STV_DEFAULT U __UFT_OFFSET
STT_OBJECT  STB_WEAK  STV_DEFAULT U __UFT_CANONICAL
STT_OBJECT  STB_WEAK  STV_DEFAULT U __UDT_CANONICAL
STT_OBJECT  STB_WEAK  STV_DEFAULT U __UFT_END
STT_OBJECT  STB_WEAK  STV_DEFAULT U __UDT_END
STT_OBJECT  STB_WEAK  STV_DEFAULT U __nv.reservedSmem.offset0
STT_FUNC    STB_GLOBAL STO_ENTRY   elementwise
STT_FUNC    STB_GLOBAL STV_DEFAULT device_func_sub
STT_FUNC    STB_GLOBAL STV_DEFAULT device_func_add
PS D:\Users\xxx\WorkSpace\libmanagement> .\main_without_runtime.exe
Device: NVIDIA GeForce RTX 5060 Ti
  unified addressing:       1
  unified function pointers: 1
Loaded device.cubin
cuLibraryGetUnifiedFunction("device_func_add") failed: CUDA_ERROR_INVALID_VALUE (invalid argument)
The cubin has no unified function table (.nv.uft/.nv.udt).
ptxas emits it only for .unified_func_stub entries, which the
CUDA 12.9 toolchain does not produce for a plain
extern "C" __device__ function.
Check with: cuobjdump -symbols device.cubin | findstr UFT
      (WEAK UNDEFINED __UFT_* means no table was built)
Skipping the kernel launch; the rest of the driver-API path
still runs below.
Resolved kernel 'elementWise'
Host->device->host round trip: OK
Hi @majap7789 @fredoh1
Can you please help to give me some advice when using those api?
