The original question is here: c++ - CUDA cusolverDnSSgels error when specific shapes are used (program to find rectangular Penrose matrix inverse) - Stack Overflow
#include <cuda_runtime.h>
#include <cusolverDn.h>
#include <armadillo>
#include <iostream>
#include <string>
#include <exception>
#include <stdint.h>
#include <type_traits>
#include <limits.h>
#include <assert.h>
#include <chrono>
using namespace std;
inline void gpuAssert(cudaError_t code, const char *file, int line, bool printing = false)
if (code != cudaSuccess)
std::string mess = std::string("GPUassert: ") + std::string(cudaGetErrorString(code))
+ " " + std::string(file) + " " + std::to_string(line);
if (printing) std::cout << mess << std::endl;
throw std::runtime_error(mess.c_str());
auto lastError = cudaGetLastError();
if (lastError != cudaSuccess)
std::string mess = std::string("GPUassert: ") + std::string(cudaGetErrorString(lastError))
std::cout << "UNDETECTED_ERROR " << mess << std::endl;
// CUDA API error checking
#define CUDA_CHECK(ans) { gpuAssert((ans), __FILE__, __LINE__, true); }
#define CUDA_CHECK_NOLOG(ans) { gpuAssert((ans), __FILE__, __LINE__); }
static const char *cusolverGetErrorEnumInternal(cusolverStatus_t error)
switch (error)
case CUSOLVER_STATUS_SUCCESS:
return "CUSOLVER_SUCCESS";
case CUSOLVER_STATUS_NOT_INITIALIZED:
return "CUSOLVER_STATUS_NOT_INITIALIZED";
case CUSOLVER_STATUS_ALLOC_FAILED:
return "CUSOLVER_STATUS_ALLOC_FAILED";
case CUSOLVER_STATUS_INVALID_VALUE:
return "CUSOLVER_STATUS_INVALID_VALUE";
case CUSOLVER_STATUS_ARCH_MISMATCH:
return "CUSOLVER_STATUS_ARCH_MISMATCH";
case CUSOLVER_STATUS_EXECUTION_FAILED:
return "CUSOLVER_STATUS_EXECUTION_FAILED";
case CUSOLVER_STATUS_INTERNAL_ERROR:
return "CUSOLVER_STATUS_INTERNAL_ERROR";
case CUSOLVER_STATUS_MATRIX_TYPE_NOT_SUPPORTED:
return "CUSOLVER_STATUS_MATRIX_TYPE_NOT_SUPPORTED";
case CUSOLVER_STATUS_MAPPING_ERROR:
return "CUSOLVER_STATUS_MAPPING_ERROR";
case CUSOLVER_STATUS_NOT_SUPPORTED:
return "CUSOLVER_STATUS_NOT_SUPPORTED";
case CUSOLVER_STATUS_ZERO_PIVOT:
return "CUSOLVER_STATUS_ZERO_PIVOT";
case CUSOLVER_STATUS_INVALID_LICENSE:
return "CUSOLVER_STATUS_INVALID_LICENSE";
case CUSOLVER_STATUS_IRS_PARAMS_NOT_INITIALIZED:
return "CUSOLVER_STATUS_IRS_PARAMS_NOT_INITIALIZED";
case CUSOLVER_STATUS_IRS_PARAMS_INVALID:
return "CUSOLVER_STATUS_IRS_PARAMS_INVALID";
case CUSOLVER_STATUS_IRS_PARAMS_INVALID_PREC:
return "CUSOLVER_STATUS_IRS_PARAMS_INVALID_PREC";
case CUSOLVER_STATUS_IRS_PARAMS_INVALID_REFINE:
return "CUSOLVER_STATUS_IRS_PARAMS_INVALID_REFINE";
case CUSOLVER_STATUS_IRS_PARAMS_INVALID_MAXITER:
return "CUSOLVER_STATUS_IRS_PARAMS_INVALID_MAXITER";
case CUSOLVER_STATUS_IRS_INTERNAL_ERROR:
return "CUSOLVER_STATUS_IRS_INTERNAL_ERROR";
case CUSOLVER_STATUS_IRS_NOT_SUPPORTED:
return "CUSOLVER_STATUS_IRS_NOT_SUPPORTED";
case CUSOLVER_STATUS_IRS_OUT_OF_RANGE:
return "CUSOLVER_STATUS_IRS_OUT_OF_RANGE";
case CUSOLVER_STATUS_IRS_NRHS_NOT_SUPPORTED_FOR_REFINE_GMRES:
return "CUSOLVER_STATUS_IRS_NRHS_NOT_SUPPORTED_FOR_REFINE_GMRES";
case CUSOLVER_STATUS_IRS_INFOS_NOT_INITIALIZED:
return "CUSOLVER_STATUS_IRS_INFOS_NOT_INITIALIZED";
case CUSOLVER_STATUS_IRS_INFOS_NOT_DESTROYED:
return "CUSOLVER_STATUS_IRS_INFOS_NOT_DESTROYED";
case CUSOLVER_STATUS_IRS_MATRIX_SINGULAR:
return "CUSOLVER_STATUS_IRS_MATRIX_SINGULAR";
case CUSOLVER_STATUS_INVALID_WORKSPACE:
return "CUSOLVER_STATUS_INVALID_WORKSPACE";
return "CUSOLVER_UNKNOWN_ERROR";
inline void cusolveSafeCallInternal(cusolverStatus_t err, const char *file, const int line)
if (CUSOLVER_STATUS_SUCCESS != err) {
std::string mess = std::string("CUSOLVER error in file ") + std::string(file) + ", line " + std::to_string(line)
+ ", error: " + std::string(cusolverGetErrorEnumInternal(err));
throw std::runtime_error(mess);
#define cusolveSafeCall(err) { cusolveSafeCallInternal((err), __FILE__, __LINE__); }
class MyTimer {
std::chrono::time_point<std::chrono::system_clock> start;
public:
void startCounter() {
start = std::chrono::system_clock::now();
int64_t getCounterNs() {
return std::chrono::duration_cast<std::chrono::nanoseconds>(std::chrono::system_clock::now() - start).count();
int64_t getCounterMs() {
return std::chrono::duration_cast<std::chrono::milliseconds>(std::chrono::system_clock::now() - start).count();
double getCounterMsPrecise() {
/ 1000000.0;
double eps_ = 1e-6;
template <typename num_t = double>
num_t rcmp(double a, double b, double eps = eps_) {
if (std::isnan(a) && std::isnan(b)) return 0;
if (std::isnan(a + b)) return NAN;
num_t t = (a - b) / std::max((num_t)1, std::max(std::abs(a), std::abs(b)));
return t < -eps ? -1 : +eps < t;
template <typename T>
void test(int64_t M, int64_t N, int64_t nrhs)
int error_code = 0;
arma::Mat<T> A(M, N, arma::fill::randn);
arma::Mat<T> X(N, nrhs, arma::fill::randn);
arma::Mat<T> B = A * X;
X = solve(A, B);
cusolverDnHandle_t cusolverH;
cusolveSafeCall(cusolverDnCreate(&cusolverH));
int64_t ldda = M;
int64_t lddb = M;
int64_t lddx = N;
T *d_A, *d_B, *d_X;
CUDA_CHECK(cudaMallocManaged(&d_A, M * N * sizeof(T)));
CUDA_CHECK(cudaMallocManaged(&d_X, N * nrhs * sizeof(T)));
CUDA_CHECK(cudaMallocManaged(&d_B, M * nrhs * sizeof(T)));
CUDA_CHECK(cudaMemcpy(d_A, A.memptr(), M * N * sizeof(T), cudaMemcpyDefault));
CUDA_CHECK(cudaMemcpy(d_B, B.memptr(), M * nrhs * sizeof(T), cudaMemcpyDefault));
CUDA_CHECK(cudaDeviceSynchronize());
size_t lwork_bytes = 0;
if constexpr(std::is_same_v<T, float>) {
cusolveSafeCall(cusolverDnSSgels_bufferSize(
cusolverH,
M, N, nrhs,
d_A, ldda,
d_B, lddb,
d_X, lddx,
NULL, &lwork_bytes
if constexpr(std::is_same_v<T, double>) {
cusolveSafeCall(cusolverDnDDgels_bufferSize(
cusolverH,
M, N, nrhs,
d_A, ldda,
d_B, lddb,
d_X, lddx,
NULL, &lwork_bytes
void* d_work;
int* d_info;
CUDA_CHECK(cudaMallocManaged(&d_work, sizeof(T) * lwork_bytes));
CUDA_CHECK(cudaMallocManaged(&d_info, sizeof(int)));
int iter = 1e9;
int info = 1e9;
try {
cusolveSafeCall(cusolverDnSSgels(
cusolverH,
M, N, nrhs,
d_A, ldda,
d_B, lddb,
d_X, lddx,
d_work, lwork_bytes,
&iter, d_info
cusolveSafeCall(cusolverDnDDgels(
cusolverH,
M, N, nrhs,
d_A, ldda,
d_B, lddb,
d_X, lddx,
&iter, d_info
} catch (const std::exception &e) {
error_code = 1;
cout << e.what() << "\n";
cudaMemcpy(&info, d_info, sizeof(int), cudaMemcpyDefault);
cout << "niters = " << iter << ", info = " << info << "\n";
arma::Mat<T> X2(N, nrhs);
memcpy(X2.memptr(), d_X, N * nrhs * sizeof(T));
arma::Mat<T> B2 = A * X2;
int wrong = 0;
for (int i = 0; i < M; i++)
for (int j = 0; j < nrhs; j++) {
auto res1 = B(i, j);
auto res2 = B2(i, j);//d_X[i + j * M];
if (rcmp(res1, res2, 1e-2)) {
cout << " wrong at " << i << " " << j << " " << res1 << " " << res2 << std::endl;
wrong++;
if (wrong >= 10) goto CLEANUP;
CLEANUP:
cudaFree(d_A);
cudaFree(d_X);
cudaFree(d_B);
cudaFree(d_work);
cudaFree(d_info);
int main()
// (2000, 1000, 2000) -> error
// (2000, 1000, 1200) -> error
// (2000, 1000, 500) -> correct
// (2000, 500, 2000) -> error
// (2000, 500, 1000) -> error
// (2000, 500, 500) -> correct
// (2000, 50, 100) -> correct
int ntest = 5;
for (int t = 1; t <= ntest; t++) {
test<float>(2000, 1000, 2000);
cout << "Finish test " << t << "\n";
To compile: nvcc -o main main.cu -O3 -std=c++17 -lcublas -lcusolver -larmadillo
I tested on on CUDA 12.1, 2080ti, gcc 10.3
The problem with this program is that it randomly gives CUSOLVER_STATUS_INVALID_VALUE error when nrhs is big enough (somewhere > 300). For small values, it seems to work okay.
Checking Nvidia doc (cuSOLVER) entry below cusolverDnSSgels, and find CUSOLVER_STATUS_INVALID_VALUE, it mentions invalid parameter. But all 4 parameters in the example they use are correct in this program. Also it outputs niters = info = 0, which isn’t a possible situation in the doc.
The code includes a few param combination that are okay/not okay. What might be the problem here?
