Hi, here are the logs
user ~ export OLLAMA_DEBUG=2 OLLAMA_IGPU_ENABLE=1
user ~ ollama serve
time=2026-10-04T15:24:54.855+08:00 level=INFO source=routes.go:1947 msg="server config" env="map[CUDA_VISIBLE_DEVICES: GGML_VK_VISIBLE_DEVICES: GPU_DEVICE_ORDINAL: HIP_VISIBLE_DEVICES: HSA_OVERRIDE_GFX_VERSION: HTTPS_PROXY: HTTP_PROXY: LLAMA_ARG_FIT: LLAMA_ARG_FIT_TARGET: NO_PROXY: OLLAMA_CONTEXT_LENGTH:0 OLLAMA_DEBUG:DEBUG-4 OLLAMA_DEBUG_LOG_REQUESTS:false OLLAMA_EDITOR: OLLAMA_FLASH_ATTENTION:false OLLAMA_GO_TEMPLATE:true OLLAMA_GPU_OVERHEAD:0 OLLAMA_HOST:http://0.0.0.0:11434 OLLAMA_IGPU_ENABLE:1 OLLAMA_KEEP_ALIVE:5m0s OLLAMA_KV_CACHE_TYPE: OLLAMA_LLM_LIBRARY: OLLAMA_LOAD_TIMEOUT:5m0s OLLAMA_MAX_LOADED_MODELS:0 OLLAMA_MAX_QUEUE:512 OLLAMA_MAX_TRANSFER_STREAMS:4 OLLAMA_MODELS:/home/user/.ollama/models OLLAMA_NOHISTORY:false OLLAMA_NOPRUNE:false OLLAMA_NO_CLOUD:false OLLAMA_NUM_PARALLEL:1 OLLAMA_ORIGINS:[http://localhost https://localhost http://localhost:* https://localhost:* http://127.0.0.1 https://127.0.0.1 http://127.0.0.1:* https://127.0.0.1:* http://0.0.0.0 https://0.0.0.0 http://0.0.0.0:* https://0.0.0.0:* app://* file://* tauri://* vscode-webview://* vscode-file://*] OLLAMA_REMOTES:[ollama.com] OLLAMA_SCHED_SPREAD:false OLLAMA_VULKAN:true ROCR_VISIBLE_DEVICES: http_proxy: https_proxy: no_proxy:]"
time=2026-10-04T15:24:54.856+08:00 level=INFO source=routes.go:1949 msg="Ollama cloud disabled: false"
time=2026-10-04T15:24:54.864+08:00 level=INFO source=images.go:883 msg="total blobs: 12"
time=2026-10-04T15:24:54.865+08:00 level=INFO source=images.go:890 msg="total unused blobs removed: 0"
time=2026-10-04T15:24:54.867+08:00 level=DEBUG source=model_recommendations.go:57 msg="starting model recommendations cache" default_recommendations=6 refresh_interval=4h0m0s fetch_timeout=3s
time=2026-10-04T15:24:54.867+08:00 level=DEBUG source=model_show_cache.go:128 msg="starting model show cache"
time=2026-10-04T15:24:54.867+08:00 level=DEBUG source=model_list_cache.go:71 msg="starting model list cache"
time=2026-10-04T15:24:54.867+08:00 level=INFO source=routes.go:2004 msg="Listening on [::]:11434 (version 0.32.0)"
time=2026-10-04T15:24:54.868+08:00 level=DEBUG source=sched.go:221 msg="starting llm scheduler"
time=2026-10-04T15:24:54.869+08:00 level=INFO source=runner.go:60 msg="discovering available GPUs..."
time=2026-10-04T15:24:54.869+08:00 level=DEBUG source=model_recommendations.go:262 msg="loaded model recommendations snapshot" path=/home/user/.ollama/cache/model-recommendations.json count=5
time=2026-10-04T15:24:54.869+08:00 level=DEBUG source=model_recommendations.go:192 msg="refreshing model recommendations from remote" url=https://ollama.com/api/experimental/model-recommendations
time=2026-10-04T15:24:54.870+08:00 level=DEBUG source=gpu.go:63 msg="unrecognized L4T version" nv_tegra_release="# R39 (release), REVISION: 2.1, GCID: 46758480, BOARD: generic, EABI: aarch64, DATE: Fri Aug 7 05:54:22 AM UTC 2026\n# KERNEL_VARIANT: oot\nTARGET_USERSPACE_LIB_DIR=nvidia\nTARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia\n"
time=2026-10-04T15:24:54.871+08:00 level=TRACE source=llama_server.go:71 msg="running llama-server for discovery" cmd=/usr/local/lib/ollama/llama-server libDirs="[/usr/local/lib/ollama /usr/local/lib/ollama/cuda_v13]"
time=2026-10-04T15:24:54.875+08:00 level=INFO source=model_list_cache.go:112 msg="model list cache hydration complete" models=5 failures=0 elapsed=7.685578ms
0.00.342.221 E ggml_cuda_init: failed to initialize CUDA: unknown error
0.00.345.575 I cmn common_param: common_params_print_info: build 1 (cb295bf59) with Clang 21.1.8 for Linux aarch64
0.00.345.584 I cmn common_param: common_params_print_info: verbosity = 2147483647 (adjust with the `-lv N` CLI arg)
0.00.347.038 I cmn common_param: system_info: n_threads = 6 (n_threads_batch = 6) / 6 | CPU : NEON = 1 | ARM_FMA = 1 | FP16_VA = 1 | DOTPROD = 1 | LLAMAFILE = 1 | REPACK = 1 | CUDA : ARCHS = 750,800,860,870,890,900,1000,1030,1100,1200,1210 | USE_GRAPHS = 1 | PEER_MAX_BATCH_SIZE = 128 |
time=2026-10-04T15:24:55.267+08:00 level=DEBUG source=llama_server.go:121 msg="llama-server discovery: stopped subprocess after collecting GPU info" exit=unknown libDirs="[/usr/local/lib/ollama /usr/local/lib/ollama/cuda_v13]"
0.00.165.746 E ggml_cuda_init: failed to initialize CUDA: unknown error
Available devices:
time=2026-10-04T15:24:55.728+08:00 level=DEBUG source=model_recommendations.go:225 msg="model recommendations refreshed" count=5
time=2026-10-04T15:24:55.734+08:00 level=DEBUG source=model_recommendations.go:302 msg="persisted model recommendations snapshot" path=/home/user/.ollama/cache/model-recommendations.json count=5
time=2026-10-04T15:24:55.734+08:00 level=INFO source=model_recommendations.go:177 msg="model recommendations cache sleep scheduled" wait=3h56m4.222731819s consecutive_failures=0
load_backend: loaded CUDA backend from /usr/local/lib/ollama/cuda_v13/libggml-cuda.so
Error: cuInit failed: 999
time=2026-10-04T15:24:55.856+08:00 level=DEBUG source=native_probe.go:259 msg="native GPU discovery failed" error="exit status 1" stderr="ggml_cuda_init: failed to initialize CUDA: unknown error\nload_backend: loaded CUDA backend from /usr/local/lib/ollama/cuda_v13/libggml-cuda.so\nError: cuInit failed: 999\n" libDirs="[/usr/local/lib/ollama /usr/local/lib/ollama/cuda_v13]"
time=2026-10-04T15:24:55.856+08:00 level=DEBUG source=llama_server.go:52 msg="llama-server device discovery took" duration=986.055231ms libDirs="[/usr/local/lib/ollama /usr/local/lib/ollama/cuda_v13]"
time=2026-10-04T15:24:55.857+08:00 level=DEBUG source=runner.go:494 msg="bootstrap discovery took" duration=986.815703ms OLLAMA_LIBRARY_PATH="[/usr/local/lib/ollama /usr/local/lib/ollama/cuda_v13]" extra_envs=map[]
time=2026-10-04T15:24:55.857+08:00 level=DEBUG source=runner.go:131 msg="evaluating which, if any, devices to filter out" initial_count=0
time=2026-10-04T15:24:55.857+08:00 level=TRACE source=runner.go:181 msg="supported GPU library combinations before filtering" supported=map[]
time=2026-10-04T15:24:55.858+08:00 level=DEBUG source=runner.go:42 msg="GPU bootstrap discovery took" duration=989.669581ms
time=2026-10-04T15:24:55.858+08:00 level=INFO source=types.go:50 msg="inference compute" id=cpu library=cpu compute="" name=cpu description=cpu libdirs=ollama driver="" pci_id="" type="" total="7.4 GiB" available="585.6 MiB"
time=2026-10-04T15:24:55.859+08:00 level=INFO source=routes.go:2054 msg="vram-based default context" total_vram="0 B" default_num_ctx=4096
[GIN] 2026/10/04 - 15:25:22 | 200 | 1.813207ms | 127.0.0.1 | HEAD "/"
[GIN] 2026/10/04 - 15:25:22 | 200 | 6.954228ms | 127.0.0.1 | GET "/api/tags"
[GIN] 2026/10/04 - 15:25:30 | 200 | 43.169µs | 127.0.0.1 | HEAD "/"
time=2026-10-04T15:25:30.667+08:00 level=TRACE source=ggml.go:327 msg="key with type not found" key=general.alignment default=32
[GIN] 2026/10/04 - 15:25:30 | 200 | 236.938178ms | 127.0.0.1 | POST "/api/show"
[GIN] 2026/10/04 - 15:25:30 | 200 | 2.522413ms | 127.0.0.1 | POST "/api/show"
time=2026-10-04T15:25:31.011+08:00 level=TRACE source=sched.go:247 msg="processing incoming request" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.012+08:00 level=TRACE source=sched.go:281 msg="refreshing GPU list" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.012+08:00 level=DEBUG source=runner.go:272 msg="refreshing free memory"
time=2026-10-04T15:25:31.012+08:00 level=DEBUG source=runner.go:42 msg="overall device VRAM discovery took" duration=385.868µs
time=2026-10-04T15:25:31.012+08:00 level=TRACE source=sched.go:284 msg="refreshing system information" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.012+08:00 level=TRACE source=gpu.go:22 msg="performing system memory discovery"
time=2026-10-04T15:25:31.012+08:00 level=TRACE source=gpu.go:25 msg="system memory discovery completed" duration=177.349µs
time=2026-10-04T15:25:31.012+08:00 level=DEBUG source=sched.go:296 msg="updating default concurrency" OLLAMA_MAX_LOADED_MODELS=3 gpu_count=0
time=2026-10-04T15:25:31.012+08:00 level=TRACE source=sched.go:300 msg="updating free space" gpu_count=0 model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.012+08:00 level=DEBUG source=sched.go:305 msg="loading first model" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.076+08:00 level=TRACE source=ggml.go:327 msg="key with type not found" key=general.alignment default=32
time=2026-10-04T15:25:31.077+08:00 level=INFO source=sched.go:1158 msg="disabling mmap for llama-server load by default" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb reason=cpu
time=2026-10-04T15:25:31.077+08:00 level=INFO source=server.go:109 msg="using llama-server for model" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.077+08:00 level=TRACE source=ggml.go:327 msg="key with type not found" key=llama.nextn_predict_layers default=0
time=2026-10-04T15:25:31.078+08:00 level=INFO source=llama_server.go:433 msg="starting llama-server" cmd="/usr/local/lib/ollama/llama-server --model /home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb --port 39025 --host 127.0.0.1 --no-webui --offline -c 4096 -np 1 --log-verbosity 4 --no-log-prefix --no-log-timestamps --no-mmap --flash-attn auto -b 512 -ub 512 --context-shift --keep 4"
time=2026-10-04T15:25:31.078+08:00 level=DEBUG source=llama_server.go:434 msg=subprocess GGML_BACKEND_PATH=/usr/local/lib/ollama/cuda_v13/libggml-cuda.so LD_LIBRARY_PATH=/usr/local/lib/ollama:/usr/local/lib/ollama/cuda_v13 PATH=/home/user/iOS/netmuxd/target/release:/home/user/KataGo/cpp:/home/user/Arduino-IDE:/home/user/iOS/netmuxd/target/release:/home/user/.opencode/bin:/home/user/.atuin/bin:/home/linuxbrew/.linuxbrew/bin:/home/linuxbrew/.linuxbrew/sbin:/opt/devkitpro/tools/bin:/home/user/.cargo/bin:/home/user/openpilot/.venv/bin:/home/user/.local/bin:/home/user/.nvm/versions/node/v24.12.0/bin:/usr/local/cuda-12.6/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/user/.local/bin:/home/user/.lmstudio/bin:/usr/local/go/bin:/home/user/go/bin
time=2026-10-04T15:25:31.079+08:00 level=INFO source=sched.go:623 msg="system memory" total="7.4 GiB" free="391.1 MiB" free_swap="21.3 GiB"
time=2026-10-04T15:25:31.079+08:00 level=INFO source=llama_server.go:1001 msg="loading model via llama-server" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:31.079+08:00 level=INFO source=llama_server.go:1248 msg="waiting for llama-server to start responding"
time=2026-10-04T15:25:31.080+08:00 level=INFO source=llama_server.go:1303 msg="waiting for llama-server to become available" status="llm server not responding"
0.00.355.251 E ggml_cuda_init: failed to initialize CUDA: unknown error
cmn common_param: common_params_print_info: verbosity = 4 (adjust with the `-lv N` CLI arg)
cmn common_param: device_info:
cmn common_param: - CPU : CPU (7546 MiB, 7546 MiB free)
srv init: using 5 threads for HTTP server
srv init: The UI is disabled
srv init: Use --ui/--no-ui (or deprecated --webui/--no-webui) to enable/disable
srv start: binding port with default address family
srv load_model: loading model '/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb'
srv load_model: local path '/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb'
cmn common_init_: fitting params to device memory ...
cmn common_init_: (for bugs during this step try to reproduce them with -fit off, or provide --verbose logs if the bug only occurs with -fit on)
common_params_fit_impl: getting device memory data for initial parameters:
time=2026-10-04T15:25:31.586+08:00 level=INFO source=llama_server.go:1303 msg="waiting for llama-server to become available" status="llm server loading model"
common_memory_breakdown_print: | memory breakdown [MiB] | total free self model context compute unaccounted |
common_memory_breakdown_print: | - Host | 368 = 144 + 168 + 56 |
common_memory_breakdown_print: | - CPU_REPACK | 1339 = 1339 + 0 + 0 |
common_params_fit_impl: projected to use 368 MiB of host memory vs. 7546 MiB of total host memory
common_params_fit_impl: will leave 7177 >= 1024 MiB of system memory, no changes needed
common_fit_params: successfully fit params to free device memory
common_fit_params: fitting params to free memory took 0.55 seconds
llama_model_loader: loaded meta data with 76 key-value pairs and 381 tensors from /home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb (version GGUF V3 (latest))
llama_model_loader: Dumping metadata keys/values. Note: KV overrides do not apply in this output.
llama_model_loader: - kv 0: general.architecture str = llama
llama_model_loader: - kv 1: general.type str = model
llama_model_loader: - kv 2: general.sampling.top_p f32 = 0.950000
llama_model_loader: - kv 3: general.sampling.temp f32 = 1.000000
llama_model_loader: - kv 4: general.name str = MiniCPM5 2B Heretic Abliterated
llama_model_loader: - kv 5: general.finetune str = heretic-abliterated
llama_model_loader: - kv 6: general.basename str = MiniCPM5
llama_model_loader: - kv 7: general.size_label str = 2B
llama_model_loader: - kv 8: general.license str = apache-2.0
llama_model_loader: - kv 9: general.dataset.count u32 = 8
llama_model_loader: - kv 10: general.dataset.0.name str = Ultra FineWeb
llama_model_loader: - kv 11: general.dataset.0.organization str = Openbmb
llama_model_loader: - kv 12: general.dataset.0.repo_url str = https://huggingface.co/openbmb/Ultra-...
llama_model_loader: - kv 13: general.dataset.1.name str = UltraX Preview
llama_model_loader: - kv 14: general.dataset.1.organization str = Openbmb
llama_model_loader: - kv 15: general.dataset.1.repo_url str = https://huggingface.co/openbmb/UltraX...
llama_model_loader: - kv 16: general.dataset.2.name str = Ultra FineWeb L3
llama_model_loader: - kv 17: general.dataset.2.organization str = Openbmb
llama_model_loader: - kv 18: general.dataset.2.repo_url str = https://huggingface.co/openbmb/Ultra-...
llama_model_loader: - kv 19: general.dataset.3.name str = UltraData Math
llama_model_loader: - kv 20: general.dataset.3.organization str = Openbmb
llama_model_loader: - kv 21: general.dataset.3.repo_url str = https://huggingface.co/openbmb/UltraD...
llama_model_loader: - kv 22: general.dataset.4.name str = UltraData Code
llama_model_loader: - kv 23: general.dataset.4.organization str = Openbmb
llama_model_loader: - kv 24: general.dataset.4.repo_url str = https://huggingface.co/openbmb/UltraD...
llama_model_loader: - kv 25: general.dataset.5.name str = UltraData SFT 2605
llama_model_loader: - kv 26: general.dataset.5.version str = 2605
llama_model_loader: - kv 27: general.dataset.5.organization str = Openbmb
llama_model_loader: - kv 28: general.dataset.5.repo_url str = https://huggingface.co/openbmb/UltraD...
llama_model_loader: - kv 29: general.dataset.6.name str = UltraData SFT Agent 2609
llama_model_loader: - kv 30: general.dataset.6.version str = 2609
llama_model_loader: - kv 31: general.dataset.6.organization str = Openbmb
llama_model_loader: - kv 32: general.dataset.6.repo_url str = https://huggingface.co/openbmb/UltraD...
llama_model_loader: - kv 33: general.dataset.7.name str = UltraData RL 2609
llama_model_loader: - kv 34: general.dataset.7.version str = 2609
llama_model_loader: - kv 35: general.dataset.7.organization str = Openbmb
llama_model_loader: - kv 36: general.dataset.7.repo_url str = https://huggingface.co/openbmb/UltraD...
llama_model_loader: - kv 37: general.tags arr[str,14] = ["minicpm", "minicpm5", "llama", "tex...
llama_model_loader: - kv 38: general.languages arr[str,2] = ["en", "zh"]
llama_model_loader: - kv 39: llama.block_count u32 = 42
llama_model_loader: - kv 40: llama.context_length u32 = 131072
llama_model_loader: - kv 41: llama.embedding_length u32 = 2048
llama_model_loader: - kv 42: llama.feed_forward_length u32 = 6144
llama_model_loader: - kv 43: llama.attention.head_count u32 = 16
llama_model_loader: - kv 44: llama.attention.head_count_kv u32 = 2
llama_model_loader: - kv 45: llama.rope.freq_base f32 = 5000000.000000
llama_model_loader: - kv 46: llama.attention.layer_norm_rms_epsilon f32 = 0.000001
llama_model_loader: - kv 47: llama.attention.key_length u32 = 128
llama_model_loader: - kv 48: llama.attention.value_length u32 = 128
llama_model_loader: - kv 49: llama.vocab_size u32 = 130560
llama_model_loader: - kv 50: llama.rope.dimension_count u32 = 128
llama_model_loader: - kv 51: tokenizer.ggml.model str = gpt2
llama_model_loader: - kv 52: tokenizer.ggml.pre str = minicpm5
llama_model_loader: - kv 53: tokenizer.ggml.tokens arr[str,130560] = ["<s>", "</s>", "<tool_call>", "</too...
llama_model_loader: - kv 54: tokenizer.ggml.token_type arr[i32,130560] = [3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 3, 3, ...
llama_model_loader: - kv 55: tokenizer.ggml.merges arr[str,129794] = ["Ġ t", "h e", "Ġ a", "i n", "Ġ Ġ...
llama_model_loader: - kv 56: tokenizer.ggml.bos_token_id u32 = 0
llama_model_loader: - kv 57: tokenizer.ggml.eos_token_id u32 = 1
llama_model_loader: - kv 58: tokenizer.ggml.unknown_token_id u32 = 130074
llama_model_loader: - kv 59: tokenizer.ggml.padding_token_id u32 = 1
llama_model_loader: - kv 60: tokenizer.ggml.add_bos_token bool = true
llama_model_loader: - kv 61: tokenizer.ggml.add_sep_token bool = false
llama_model_loader: - kv 62: tokenizer.chat_template str = {{- bos_token }}{%- if tools %}\n {...
llama_model_loader: - kv 63: general.quantization_version u32 = 2
llama_model_loader: - kv 64: general.file_type u32 = 15
llama_model_loader: - kv 65: general.url str = https://huggingface.co/mradermacher/M...
llama_model_loader: - kv 66: mradermacher.quantize_version str = 2
llama_model_loader: - kv 67: mradermacher.quantized_by str = mradermacher
llama_model_loader: - kv 68: mradermacher.quantized_at str = 2026-09-08T16:43:47+02:00
llama_model_loader: - kv 69: mradermacher.quantized_on str = back
llama_model_loader: - kv 70: general.source.url str = https://huggingface.co/insraq/MiniCPM...
llama_model_loader: - kv 71: mradermacher.convert_type str = hf
llama_model_loader: - kv 72: quantize.imatrix.file str = MiniCPM5-2B-heretic-abliterated-i1-GG...
llama_model_loader: - kv 73: quantize.imatrix.dataset str = imatrix-training-full-3
llama_model_loader: - kv 74: quantize.imatrix.entries_count u32 = 294
llama_model_loader: - kv 75: quantize.imatrix.chunks_count u32 = 312
llama_model_loader: - type f32: 85 tensors
llama_model_loader: - type q4_K: 253 tensors
llama_model_loader: - type q6_K: 43 tensors
print_info: file format = GGUF V3 (latest)
print_info: file type = Q4_K - Medium
print_info: file size = 1.45 GiB (4.95 BPW)
load: 478 unused tokens
load: printing all EOG tokens:
load: - 1 ('</s>')
load: - 130073 ('<|im_end|>')
load: special tokens cache size = 510
load: token to piece cache size = 0.8291 MB
print_info: arch = llama
print_info: vocab_only = 0
print_info: no_alloc = 0
print_info: n_ctx_train = 131072
print_info: n_embd_inp = 2048
print_info: n_embd = 2048
print_info: n_embd_out = 2048
print_info: n_layer = 42
print_info: n_layer_all = 42
print_info: n_head = 16
print_info: n_head_kv = 2
print_info: n_rot = 128
print_info: n_swa = 0
print_info: is_swa_any = 0
print_info: n_embd_head_k = 128
print_info: n_embd_head_v = 128
print_info: n_gqa = 8
print_info: n_embd_k_gqa = 256
print_info: n_embd_v_gqa = 256
print_info: f_norm_eps = 0.0e+00
print_info: f_norm_rms_eps = 1.0e-06
print_info: f_clamp_kqv = 0.0e+00
print_info: f_max_alibi_bias = 0.0e+00
print_info: f_logit_scale = 0.0e+00
print_info: f_attn_scale = 0.0e+00
print_info: f_attn_value_scale = 0.0000
print_info: n_ff = 6144
print_info: n_expert = 0
print_info: n_expert_used = 0
print_info: n_expert_groups = 0
print_info: n_group_used = 0
print_info: causal attn = 1
print_info: pooling type = -1
print_info: rope type = 0
print_info: rope scaling = linear
print_info: freq_base_train = 5000000.0
print_info: freq_scale_train = 1
print_info: n_ctx_orig_yarn = 131072
print_info: rope_yarn_log_mul = 0.0000
print_info: rope_finetuned = unknown
print_info: model type = ?B
print_info: model params = 2.52 B
print_info: general.name = MiniCPM5 2B Heretic Abliterated
print_info: vocab type = BPE
print_info: n_vocab = 130560
print_info: n_merges = 129794
print_info: BOS token = 0 '<s>'
print_info: EOS token = 1 '</s>'
print_info: EOT token = 130073 '<|im_end|>'
print_info: UNK token = 130074 '<unk>'
print_info: PAD token = 1 '</s>'
print_info: LF token = 220 'Ċ'
print_info: FIM PRE token = 5 '<|fim_prefix|>'
print_info: FIM SUF token = 7 '<|fim_suffix|>'
print_info: FIM MID token = 6 '<|fim_middle|>'
print_info: EOG token = 1 '</s>'
print_info: EOG token = 130073 '<|im_end|>'
print_info: max token length = 1024
load_tensors: loading model tensors, this can take a while... (mmap = false, direct_io = false)
load_tensors: CPU model buffer size = 144.10 MiB
load_tensors: CPU_REPACK model buffer size = 1339.98 MiB
cmn common_init_: added </s> logit bias = -inf
cmn common_init_: added <|im_end|> logit bias = -inf
llama_context: constructing llama_context
llama_context: n_seq_max = 1
llama_context: n_ctx = 4096
llama_context: n_ctx_seq = 4096
llama_context: n_batch = 512
llama_context: n_ubatch = 512
llama_context: causal_attn = 1
llama_context: flash_attn = auto
llama_context: kv_unified = false
llama_context: freq_base = 5000000.0
llama_context: freq_scale = 1
llama_context: n_rs_seq = 0
llama_context: n_outputs_max = 1
llama_context: n_ctx_seq (4096) < n_ctx_train (131072) -- the full capacity of the model will not be utilized
llama_context: CPU output buffer size = 0.50 MiB
llama_kv_cache: CPU KV buffer size = 168.00 MiB
llama_kv_cache: size = 168.00 MiB ( 4096 cells, 42 layers, 1/1 seqs), K (f16): 84.00 MiB, V (f16): 84.00 MiB
llama_kv_cache: attn_rot_k = 0, n_embd_head_k_all = 128
llama_kv_cache: attn_rot_v = 0, n_embd_head_k_all = 128
sched_reserve: reserving ...
sched_reserve: Flash Attention was auto, set to enabled
sched_reserve: resolving fused Gated Delta Net support:
sched_reserve: fused Gated Delta Net (autoregressive) enabled
sched_reserve: fused Gated Delta Net (chunked) enabled
sched_reserve: CPU compute buffer size = 56.01 MiB
sched_reserve: graph nodes = 1308
sched_reserve: graph splits = 1
sched_reserve: reserve took 62.74 ms, sched copies = 1
cmn common_init_: warming up the model with an empty run - please wait ... (--no-warmup to disable)
srv load_model: initializing, n_slots = 1, n_ctx_slot = 4096, kv_unified = 'false'
spec common_specu: no implementations specified for speculative decoding
slot load_model: id 0 | task -1 | new slot, n_ctx = 4096
srv load_model: prompt cache is enabled, size limit: 8192 MiB
srv load_model: use `--cache-ram 0` to disable the prompt cache
srv load_model: for more info see https://github.com/ggml-org/llama.cpp/pull/16391
srv load_model: context checkpoints enabled, max = 32, min spacing = 8192
srv init: idle slots will be saved to prompt cache upon starting a new task
srv init: init: chat template, example_format: '<|im_start|>system
You are a helpful assistant<|im_end|>
<|im_start|>user
Hello<|im_end|>
<|im_start|>assistant
<think>
</think>
Hi there<|im_end|>
<|im_start|>user
How are you?<|im_end|>
<think>
srv init: init: chat template, thinking = 1
srv init: chat template supports preserving reasoning, consider enabling it via --reasoning-preserve
srv llama_server: model loaded
srv llama_server: listening on http://127.0.0.1:39025
srv update_slots: all slots are idle
time=2026-10-04T15:25:52.560+08:00 level=INFO source=llama_server.go:1315 msg="llama-server started in 21.47 seconds"
time=2026-10-04T15:25:52.936+08:00 level=INFO source=images.go:373 msg="template selection" model=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M selected=gguf_chat_template renderer="" parser="" go_template=[completion] chat_template="[tools thinking completion]" harmony=null renderer_parser=null
time=2026-10-04T15:25:52.938+08:00 level=INFO source=sched.go:739 msg="loaded runners" count=1
time=2026-10-04T15:25:52.940+08:00 level=INFO source=llama_server.go:1248 msg="waiting for llama-server to start responding"
time=2026-10-04T15:25:52.944+08:00 level=INFO source=llama_server.go:1315 msg="llama-server started in 21.86 seconds"
time=2026-10-04T15:25:52.944+08:00 level=DEBUG source=sched.go:751 msg="finished setting up" runner.name=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M runner.size="1.7 GiB" runner.vram="0 B" runner.parallel=1 runner.pid=3614723 runner.model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb runner.num_ctx=4096
[GIN] 2026/10/04 - 15:25:52 | 200 | 22.278350667s | 127.0.0.1 | POST "/api/generate"
time=2026-10-04T15:25:52.956+08:00 level=DEBUG source=sched.go:759 msg="context for request finished"
time=2026-10-04T15:25:52.956+08:00 level=DEBUG source=sched.go:400 msg="runner with non-zero duration has gone idle, adding timer" runner.name=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M runner.size="1.7 GiB" runner.vram="0 B" runner.parallel=1 runner.pid=3614723 runner.model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb runner.num_ctx=4096 duration=5m0s
time=2026-10-04T15:25:52.956+08:00 level=DEBUG source=sched.go:418 msg="after processing request finished event" runner.name=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M runner.size="1.7 GiB" runner.vram="0 B" runner.parallel=1 runner.pid=3614723 runner.model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb runner.num_ctx=4096 refCount=0
time=2026-10-04T15:25:59.421+08:00 level=DEBUG source=sched.go:1394 msg="evaluating already loaded" model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb
time=2026-10-04T15:25:59.464+08:00 level=DEBUG source=llama_server.go:1835 msg="llama-server chat request" messages=1 tools=0
srv operator(): chat format: peg-native
slot get_availabl: id 0 | task -1 | selected slot by LRU, t_last = -1
srv get_availabl: updating prompt cache
srv load: - looking for better prompt, base f_keep = -1.000, sim = 0.000
srv update: - cache state: 0 prompts, 0.000 MiB (limits: 8192.000 MiB, 4096 tokens, 8589934592 est)
srv get_availabl: prompt cache update took 0.33 ms
slot launch_slot_: id 0 | task -1 | sampler chain: logits -> penalties -> ?dry -> ?top-n-sigma -> top-k -> ?typical -> top-p -> ?min-p -> ?xtc -> temp-ext -> dist
slot launch_slot_: id 0 | task -1 | sampler params:
repeat_last_n = 64, repeat_penalty = 1.100, frequency_penalty = 0.000, presence_penalty = 0.000
dry_multiplier = 0.000, dry_base = 1.750, dry_allowed_length = 2, dry_penalty_last_n = 4096
top_k = 40, top_p = 0.900, min_p = 0.000, xtc_probability = 0.000, xtc_threshold = 0.100, typical_p = 1.000, top_n_sigma = -1.000, temp = 0.800
mirostat = 0, mirostat_lr = 0.100, mirostat_ent = 5.000, adaptive_target = -1.000, adaptive_decay = 0.900
slot launch_slot_: id 0 | task 0 | processing task, is_child = 0
slot operator(): id 0 | task 0 | new prompt, n_ctx_slot = 4096, n_keep = 4, task.n_tokens = 12
slot operator(): id 0 | task 0 | cached n_tokens = 0, memory_seq_rm [0, end)
srv stream_sessi: conv_id= (empty=1)
slot print_timing: id 0 | task 0 | prompt processing, n_tokens = 1, progress = 0.08, t = 8.82 s / 0.11 tokens per second
slot operator(): id 0 | task 0 | cached n_tokens = 1, memory_seq_rm [1, end)
slot init_sampler: id 0 | task 0 | init sampler, took 4.68 ms, tokens: text = 12, total = 12
[GIN] 2026/10/04 - 15:26:17 | 200 | 18.389665931s | 127.0.0.1 | POST "/api/chat"
time=2026-10-04T15:26:17.433+08:00 level=DEBUG source=sched.go:495 msg="context for request finished" runner.name=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M runner.size="1.7 GiB" runner.vram="0 B" runner.parallel=1 runner.pid=3614723 runner.model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb runner.num_ctx=4096
time=2026-10-04T15:26:17.444+08:00 level=DEBUG source=sched.go:400 msg="runner with non-zero duration has gone idle, adding timer" runner.name=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M runner.size="1.7 GiB" runner.vram="0 B" runner.parallel=1 runner.pid=3614723 runner.model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb runner.num_ctx=4096 duration=5m0s
time=2026-10-04T15:26:17.445+08:00 level=DEBUG source=sched.go:418 msg="after processing request finished event" runner.name=hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M runner.size="1.7 GiB" runner.vram="0 B" runner.parallel=1 runner.pid=3614723 runner.model=/home/user/.ollama/models/blobs/sha256-86e63a5218a10e095f5ed1dcf2ef1c1a9dd9af6416f4d8e9288c7562f9edd2cb runner.num_ctx=4096 refCount=0
srv stop: cancel task, id_task = 0
slot release: id 0 | task 0 | stop processing: n_tokens = 25, truncated = 0
[GIN] 2026/10/04 - 15:26:24 | 200 | 2.911481ms | 127.0.0.1 | HEAD "/"
[GIN] 2026/10/04 - 15:26:24 | 200 | 2.257318ms | 127.0.0.1 | GET "/api/ps"
and also this:
user ~ ollama ls
NAME ID SIZE MODIFIED
hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M 6263d7d0bd60 1.6 GB 2 weeks ago
gemma4:e2b 7fbdbf8f5e45 7.2 GB 3 weeks ago
gemma4:e4b c6eb396dbd59 9.6 GB 3 weeks ago
minimax-m2.7:cloud 06daa293c105 - 4 months ago
minimax-m2.5:cloud c0d5751c800f - 4 months ago
user ~ ollama run hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M
>>> hello
Thinking...
Hmm, the user said "hello". This is a simple^C>>> /bye
user ~ ollama ps
NAME ID SIZE PROCESSOR CONTEXT UNTIL
hf.co/mradermacher/MiniCPM5-2B-heretic-abliterated-i1-GGUF:Q4_K_M 6263d7d0bd60 1.8 GB 100% CPU 4096 4 minutes from now
user ~
