Environment:
OS: CentOS Linux release 7.5.1804 (Core)
DRIVER: NVIDIA-Linux-x86_64-410.93.run
CUDA: 10.1 (installed by yum: yum install cuda)
GPU: Quadro P4000
SELinux: Disabled
I installed CUDA and root can run examples made by cuda-install-samples-10.1.sh.
But some examples do not work for non-root users.
Non-root users can compile examples, and also can run 1_Utilities/deviceQuery correctly.
But 1_Utilities/bandwidthTest does not work:
$ ./bandwidthTest
[CUDA Bandwidth Test] - Starting...
Running on...
Device 0: Quadro P4000
Quick Mode
It always stops here. If root runs it, it correctly finishes:
# ./bandwidthTest
Running on...
Quick Mode
Host to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(GB/s)
32000000 12.4
Device to Host Bandwidth, 1 Device(s)
32000000 13.2
Device to Device Bandwidth, 1 Device(s)
32000000 195.2
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
Some topics mentioned that permissions of /dev/nvidia*, but they seem OK.
$ ls -l /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 Mar 7 15:06 /dev/nvidia0
crw-rw-rw- 1 root root 195, 255 Mar 7 15:06 /dev/nvidiactl
crw-rw-rw- 1 root root 195, 254 Mar 7 15:06 /dev/nvidia-modeset
crw-rw-rw- 1 root root 236, 0 Mar 7 15:06 /dev/nvidia-uvm
crw-rw-rw- 1 root root 236, 1 Mar 7 15:06 /dev/nvidia-uvm-tools
Any idea to solve it?
