I got that error, when trying to install the device drivers in compatibility mode. I assume the setup failed the first time, then Vista asked if it can reinstall using recommended settings and you said yes? So, I guess switching off compatibility with previous versions of Windows in the properties of file would help. Well, this will help to avoid that paticular error you’re getting, but I’m not sure if the installation would be successful.
