Depite what seems like an age on google I can not get CUDA demo projects to compile on OSX under eclipse, I have posted a screen cast here: http://www.saiweb.co.uk/hacking/cuda-yet-another-distraction
Can anyone point me in the right direction please?
Cheers
Oneiroi
January 14, 2009, 1:00am
#2
I’ll take that as a resounding NO then …
mfatica
January 14, 2009, 2:45am
#3
cuda+eclipse search on google:
3rd entry:
http://lifeofaprogrammergeek.blogspot.com/…evelopment.html
All the instructions on how to use it, one comment shows how to set it up for Macosx.
Oneiroi
January 14, 2009, 2:14pm
#4
As show in the screen cast I have followed the instructions layed out in that entry … they do not work.
As stated in my first post, I had been on google and tried several settings after having no luck I created the screen cast and asked here for help, instead it seems I find the general ‘google it answer’.
So AGAIN I refer to the screencast in the original post, asking what if anything is wrong.
i noticed some errors in the way you try to compile with eclipse.
first is PATH variable when you add /usr/local/cuda/bin not /usr/local/bin/cuda
second is you must compile .cu files with nvcc not gcc !!
