CUDA error 802 on GB200 system & NVIDIA fabric manager
I am on a GB200 system. I installed the CUDA toolkit via the local runfile as indicated in the developer site ([CUDA Toolkit 13.1 Downloads]). I installed nvidia-driver-590-server-open, nvidia-dkms-590-server-open, and cuda-drivers-fabricmanager-590.
I have nvidia-smi correctly reporting 4 GPUs and driver version 590.48.01.
nvidia@gb2002159g2407:~/vc/content/linux-arm64/logs$ nvidia-smi
Wed Mar 18 00:00:42 2026
| NVIDIA-SMI 590.48.01 Driver Version: 590.48.01 CUDA Version: 13.1 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GB200 Off | 00000008:01:00.0 Off | 0 |
| N/A 36C P0 N/A / 1200W | 0MiB / 189471MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA GB200 Off | 00000009:01:00.0 Off | 0 |
| | | Disabled |
| 2 NVIDIA GB200 Off | 00000018:01:00.0 Off | 0 |
| N/A 37C P0 N/A / 1200W | 0MiB / 189471MiB | 0% Default |
| | | Disabled |
| 3 NVIDIA GB200 Off | 00000019:01:00.0 Off | 0 |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
However I am seeing that the nvidia fabric manager fails to start. The precheck seems to succeed but the fabric manager does not start apparently.
nvidia@gb2002159g2407:~$ sudo systemctl status nvidia-fabricmanager.service
× nvidia-fabricmanager.service - NVIDIA fabric manager service
Loaded: loaded (/usr/lib/systemd/system/nvidia-fabricmanager.service; disabled; preset: enabled)
Active: failed (Result: exit-code) since Tue 2026-03-17 23:28:40 UTC; 22min ago
Process: 102030 ExecStartPre=/usr/bin/nvidia-fabricmanager-start.sh --mode precheck (code=exited, status=0/SUCCESS)
Process: 102092 ExecStart=/usr/bin/nvidia-fabricmanager-start.sh --mode start (code=exited, status=1/FAILURE)
CPU: 297ms
Mar 17 23:28:39 gb2002159g2407 systemd[1]: Starting nvidia-fabricmanager.service - NVIDIA fabric manager service…
Mar 17 23:28:40 gb2002159g2407 nvidia-fabricmanager-start.sh[102092]: Detected Pre-NVL5 system
Mar 17 23:28:40 gb2002159g2407 nvidia-fabricmanager-start.sh[102099]: request to query NVSwitch device information from NVSwitch driver failed with error:WARNING Nothi>
Mar 17 23:28:40 gb2002159g2407 nvidia-fabricmanager-start.sh[102092]: “/usr/bin/nv-fabricmanager -c /usr/share/nvidia/nvswitch/fabricmanager.cfg” failed! Exit code: 1
Mar 17 23:28:40 gb2002159g2407 systemd[1]: nvidia-fabricmanager.service: Control process exited, code=exited, status=1/FAILURE
Mar 17 23:28:40 gb2002159g2407 systemd[1]: nvidia-fabricmanager.service: Failed with result ‘exit-code’.
Mar 17 23:28:40 gb2002159g2407 systemd[1]: Failed to start nvidia-fabricmanager.service - NVIDIA fabric manager service.
I believe the fabric manager version is correct/matches the driver (590). Could this be due to the ‘Detected Pre-NVL5 System’ message? I don’t quite understand what this message refers to.
Also will this error with the fabric manager cause the CUDA runtime to fail to initialize? When attempting to run the Superbench benchmark, I see
UserWarning: CUDA initialization: Unexpected error from cudaGetDeviceCount(). Did you run some cuda functions before calling NumCudaDevices() that might have already set an error? Error 802: system not yet initialized
