../rtSafe/cuda/reformat.cu (1362) - Cuda Error in nhwcTonchwLaunch: 700 (an illegal memory access was encountered) FAILED_EXECUTION: std::exception
when I try to run TRT engine as;
at::Tensor spatial_features = torch::zeros({1, Config::num_input_channels, Config::grid_size_y, Config::grid_size_x},
torch::TensorOptions().device(device_).dtype(torch::kFloat));
if (network_trt_ptr && network_trt_ptr->context_) {
std::vector<void *> buffers = {spatial_features.data_ptr(), output_center_t_.data_ptr(),
output_center_z_t_.data_ptr(), output_dim_t_.data_ptr(),
output_rot_t_.data_ptr(), output_heatmap_t_.data_ptr()
bool ret = network_trt_ptr->context_->executeV2(buffers.data());
And here is the onnx file i used to create my engine. Additionally I can run this engine in trtexec and it passes the test there.
livox_centerpoint_backbone_head.onnx (4.7 MB)
