I have a problem when i run a executable example file by cross compiling, the file just run several seconds and nothing displayed, just a transparent window. the error shows that:
vidia@tegra-ubuntu:~/Desktop/test2/Debug$ ./test4
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
[CUDA FFT Ocean Simulation]
Left mouse button - rotate
Middle mouse button - pan
Right mouse button - zoom
'w' key - toggle wireframe
GPU Device 0: "DRIVE PX 2 AutoChauffeur" with compute capability 6.1
CUDA error at ../src/oceanFFT.cpp:296 code=71(cudaErrorNotSupported) "cudaGraphicsGLRegisterBuffer(&cuda_heightVB_resource, heightVertexBuffer, cudaGraphicsMapFlagsWriteDiscard)"
thanks all…
