I’m running a deepstream app on Xavier NX ,
I’m getting the following error :
Opening in BLOCKING MODE
ERROR: Failed to set cuda device (3)., cuda err_no:101, err_str:cudaErrorInvalidDevice
0:00:00.514800080 546 0x39b8aa10 ERROR nvinfer gstnvinfer.cpp:674:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::~NvDsInferContextImpl() <nvdsinfer_context_impl.cpp:2045> [UID = 1]: Failed to set cuda device 3 (cudaErrorInvalidDevice).
0:00:00.514911504 546 0x39b8aa10 WARN nvinfer gstnvinfer.cpp:888:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:00.514946928 546 0x39b8aa10 WARN nvinfer gstnvinfer.cpp:888:gst_nvinfer_start: error: Config file path: dstest_segmentation_config_industrial.txt, NvDsInfer Error: NVDSINFER_CUDA_ERROR
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(888): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-nvinference-engine:
EDIT- Issue solved , gpu-id in my config was set to 3
