• DeepStream Version
• TensorRT Version
Good morning,
I have been facing an issue for a few months that I am not trying to fix. We have internal software that goes through a list of models and runs a pipeline one after another. After running 3-7 pipelines in a row, I sometimes get this error below. The config associated with the pipeline works as when I re-run the pipeline that had an error there is no issue - it only happens when I queue multiple pipelines one after another.
My guess is that between each pipeline there is a memory allocation that sometimes is not released. Can you advise on how to fix this issue? This issue occurs when running tlt-converter or right before a pipeline is started
We are using deepstream-5.1 with TLT/TAO models
ERROR: nvdsinfer_context_impl.cpp:1573 Failed to synchronize on cuda copy-coplete-event, cuda err_no:700, err_str:cudaErrorIllegalAddress
0:00:01.229666287 976 0x24a3ed0 WARN nvinfer gstnvinfer.cpp:2021:gst_nvinfer_output_loop:<primary-inference> error: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR
0:00:01.229755945 976 0x24a3ed0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::releaseBatchOutput() <nvdsinfer_context_impl.cpp:1599> [UID = 1]: Tried to release an unknown outputBatchID
Error: gst-stream-error-quark: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR (1): gstnvinfer.cpp(2021): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference
