I’m running a saved engine using python wrapper of tensorrt. I have ~26000 test images, it runs correctly on 368 images, but throws this error when I increase number of images from 368 to 369 (ideally it should work for 26000 images):
/usr/local/lib/python3.5/dist-packages/h5py/__init__.py:34: FutureWarning: Conversion of the second argument of issubdtype from `float` to `np.floating` is deprecated. In future, it will be treated as `np.float64 == np.dtype(float).type`.
from ._conv import register_converters as _register_converters
[TensorRT] ERROR: cudnnEngine.cpp (56) - Cuda Error in initializeCommonContext: 4
terminate called after throwing an instance of 'nvinfer1::CudaError'
what(): std::exception
Aborted (core dumped)
I am passing one image at a time in a for loop, my guess is it has something to do with memory. Here’s python code I am using
#test the formed engine on the image by running an infernece
import pycuda.driver as cuda
import pycuda.autoinit
import numpy as np
import tensorrt as trt
from random import randint
from PIL import Image
from matplotlib.pyplot import imshow #to show test case
from tensorrt import parsers
from tensorflow.python.framework import graph_util
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.ERROR)
INPUT_H = 32
INPUT_W = 32
OUTPUT_SIZE = 10
DATA = '/home/d/Desktop/model_compare_caffe/svhn/svhn_test_images/'
IMAGE_MEAN = '/home/d/Desktop/model_compare_caffe/svhn/trt/svhn_trt.binaryproto'
RESULT_FILE = '/home/d/Desktop/model_compare_caffe/svhn/svhn_test_images.txt'
accuracy = 0
max_range = 380
f = open(RESULT_FILE, "r")
fs = f.read()
words = fs.split()
number = [int(w) for w in words]
# for i in range(0, max_range):
# print(number[i])
# rand_file = randint(0,10)
# path = DATA + str(rand_file) + '.png'
for current_image in range(0, max_range):
# print(i)
path = DATA + str(current_image) + '.png'
im = Image.open(path)
imshow(np.asarray(im))
arr = np.array(im)
img = arr.ravel()
parser = parsers.caffeparser.create_caffe_parser()
mean_blob = parser.parse_binary_proto(IMAGE_MEAN)
parser.destroy()
#NOTE: This is different than the C++ API, you must provide the size of the data
mean = mean_blob.get_data(INPUT_W ** 2)
data = np.empty([INPUT_W ** 2])
for i in range(INPUT_W ** 2):
data[i] = float(img[i]) - mean[i]
mean_blob.destroy()
runtime = trt.infer.create_infer_runtime(G_LOGGER)
engine = trt.utils.load_engine(G_LOGGER, "new_mnist.engine")
context = engine.create_execution_context()
assert(engine.get_nb_bindings() == 2)
#convert input data to Float32
img = img.astype(np.float32)
#create output array to receive data
output = np.empty(OUTPUT_SIZE, dtype = np.float32)
d_input = cuda.mem_alloc(1 * img.size * img.dtype.itemsize)
d_output = cuda.mem_alloc(1 * output.size * output.dtype.itemsize)
bindings = [int(d_input), int(d_output)]
stream = cuda.Stream()
#transfer input data to device
cuda.memcpy_htod_async(d_input, img, stream)
#execute model
context.enqueue(1, bindings, stream.handle, None)
#transfer predictions back
cuda.memcpy_dtoh_async(output, d_output, stream)
#syncronize threads
stream.synchronize()
if(np.argmax(output) == number[current_image]):
# print('Success')
accuracy = accuracy+1;
# else:
# print('Failure')
# print(number[current_image], " -> ", str(np.argmax(output)))
print('---------------------------------------------------------------------')
print('total corect solution : ', accuracy)
print('in % : ', (accuracy/max_range)*100)
#print("runtime details : ", type(runtime))
context.destroy()
engine.destroy()
runtime.destroy()
Any suggestion ?
