i have a problem with my kernel. I get an exception from an Illegal address, and the debugger gives me a line, but i can’t find the mistake. Where can the array be erased?
On my Q600 with tk 4 it works fine,
on a cluster with Tesla C2050 tk 3.2 it fails
both compiled with sm_20
Thanks,
mic
__global__ void ExactKernel()
unsigned int tid = threadIdx.x + blockIdx.x * blockDim.x; //get total id of the current thread
if(tid>c_numsr-1) return; //if more threads started than needed
unsigned int srlength = c_srlength;
unsigned char *l_SR = (unsigned char *)malloc(sizeof(char)*srlength); //= (unsigned char *)malloc(sizeof(unsigned char)*c_srlength);
//copy Sr to local variable
for(int i=0; i<srlength; i++){
l_SR[i] = k_sr[tid*srlength+i];
if(l_SR[i]>3) return; //no match possible
* run search on forward strand
int fwd = SearchPart(tid, l_SR, 0);
* if no hit found, search on reverse strand
if(fwd==0){
unsigned char *l_SR_bwd = (unsigned char *)malloc(sizeof(char)*srlength);
switch(l_SR[i]){
case 0: l_SR_bwd[srlength-i-1] = 3; break; //A->T
case 1: l_SR_bwd[srlength-i-1] = 2; break; //C->G
case 2: l_SR_bwd[srlength-i-1] = 1; break; //G->C
case 3: l_SR_bwd[srlength-i-1] = 0; break; //T->A
SearchPart(tid, l_SR_bwd, 1);
free(l_SR_bwd);
free(l_SR);
Program received signal CUDA_EXCEPTION_1, Lane Illegal Address.
[Switching to CUDA Kernel 1 (<<<(32,0),(65,0,0)>>>)]
0x000000001cc353f8 in ExactKernel () at kernel_nomm.cu:789
789 switch(l_SR[i]){
(cuda-gdb)
