• Hardware Platform (Jetson / GPU) GPU 3090 • DeepStream Version 7.1 docker
use nvmultiurisrcbin, in end of stream get this error
86783
{'source_id': 0, 'pts': 89918954644444, 'ntp': 0, 'width': 2560, 'height': 1440, 'frame_num': 70900, 'objects': []}
test5app
0
86784
Warning: gst-resource-error-quark: No Sources found at the input of muxer. Waiting for sources. (3): gstnvstreammux.cpp(2893): gst_nvstreammux_src_push_loop (): /GstPipeline:pipeline0/GstDsNvMultiUriBin:multi-uri/GstBin:multi-uri_creator/GstNvStreamMux:src_bin_muxer
Cuda failure: status=700
nvbufsurface: Error(-1) in releasing cuda memory
I am sorry that I am unable to upgrade the driver at the moment because there are some important programs running. I will upgrade the driver at the appropriate time. If you are certain it is a driver issue, I will consider your suggestion and close it.
