CUDA failure with Orin Nano module - L4T36.3.0, Jetpack6.0
We are using Customer carrier board and L4T36.3.0, Jetpack6.0.
Running ./deviceQuery is giving below error with Orin Nano 4GB and Orin Nano 8GB module.
but when we run the same sample(./deviceQuery) with same BSP on Orin NX module it is passing. Below is the log of the same. The same steps we are trying on Orin Nano.
Orin_NX_CUDA_log.txt (496.5 KB)
Is there any specific change that we need to do for Orin Nano related to CUDA.
Hi
Is the Orin NX working case also using the customer carrier board?
Hi
Yes, we are using the same customer carrier board with Orin NX.
Any update on this issue?
Sorry for the late update.
We are checking this internally. Will provide more info to you later.
I don’t think there is anything different between NX and Nano in this part.
Is your issue reproducible on NV devkit?
