I wanted to install scikit-cuda to accelerate FFT and it complained about not finding cuda.h. I followed this tutorial Installing CUDA on Nvidia Jetson Nano - JFrog Connect and after fixing errors, I managed to pip install scikit-cuda, but it doesn’t work.
nvidia-smi says NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Importing pycuda yields
File “”, line 1, in
File “/home/paul/.local/lib/python3.8/site-packages/pycuda/autoinit.py”, line 5, in
cuda.init()
pycuda._driver.Error: cuInit failed: unknown error
I have nvcc.
nvcc --version
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Thu_Jun_11_22:26:42_PDT_2020
Cuda compilation tools, release 11.0, V11.0.194
Build cuda_11.0_bu.TC445_37.28540450_0
In bashrc I put:
export PATH=“/usr/local/cuda/bin:${PATH}”
export LD_LIBRARY_PATH=“/usr/local/cuda/lib64:${LD_LIBRARY_PATH}”
export CPATH=$CPATH:/usr/local/cuda-11.0/targets/sbsa-linux/include
export LIBRARY_PATH=$LIBRARY_PATH:/usr/local/cuda-11.0/targets/sbsa-linux/lib
Is there something I can do to repair this? Thanks!
LE: I installed CUDA with SDK Manager after some battles :D
nvidia-smi doesn’t exist anymore, but the pip package is working. This can be closed I think.
