I have a problem installing CUDA.
I installed the CUDA Toolkit, Drivers (185.85) and SDK v2.2 for Windows XP Pro 64-bit (SP2).
When I run deviceQuery.exe I get:
CUDA Device Query (Runtime API) version (CUDART static linking)
There is no device supporting CUDA.
Device 0: "Device Emulation (CPU)"
CUDA Capability Major revision number: 9999
CUDA Capability Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Run time limit on kernels: No
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
Why no support for CUDA? Is it the card or something else wrong?
nvcuda.dll is properly installed in my system32 folder.
On this webpage:
http://www.nvidia.com/object/cuda_learn_products.html
The Quadro FX 5500 is not listed. However, both the 4800 and 5600 are listed, which seems odd they would skip it.
Can someone verify for me whether or not this card is officially supported?
