CUDA Fortran and PUBLIC/PRIVATE
An odd question, but one I thought I’d ask about. Namely, how compatible is CUDA Fortran with PUBLIC and PRIVATE (and, I suppose, PROTECTED)?
I ask because I was recently trying to clean up some CUDA Fortran modules with some data hiding (as we all should do using modules) and ran into issues.
As a test example to show these, I hacked some matmul code that looked like:
module mmul_mod
use cudafor
implicit none
real, allocatable, dimension(:,:), device :: A_dev, B_dev, C_dev
contains
   attributes(global) subroutine mmul_kernel(N,M,L)
This worked just fine, obviously. I then tried:
module mmul_mod
use cudafor
implicit none
PRIVATE
PUBLIC :: A_dev, B_dev, C_dev
contains
Also worked. But, when I try:
module mmul_mod
use cudafor
implicit none
PRIVATE
real, allocatable, dimension(:,:), device, PUBLIC :: A_dev, B_dev, C_dev
contains
the compiler bombs out with:
pgfortran -Minfo -Mcuda -c mmul_mod.F90
PGF90-S-0134-Illegal attribute - conflict with access (mmul_mod.F90: 8)
  0 inform,   0 warnings,   1 severes, 0 fatal for mmul_mod
make: *** [mmul_mod.o] Error 2
As the real code I’m working often has 20-30 device variables (or more) and many constants, I’m not too keen on adding 20-30 extra lines PUBLIC’ing the device variables in addition to all the REAL, ALLOCATABLE, DEVICE declarations. Is there a way I can PUBLIC these on the same line as they are declared?
Also, I guess I should ask: are attributes(global) subroutines and functions inherently PUBLIC? Notice above I never declared mmul_kernel as PUBLIC, and yet it worked just fine. (And, the corollary: are attributes(device) subroutines and functions inherently PRIVATE?)
Thanks,
Matt
PS: I did try the above module with just PRIVATE and no PUBLIC and it bombs out in the way you’d expect. A_dev et al aren’t declared in the USEing routine, etc.
Quite frankly, we haven’t paid much attention to attributes like public and private in combination with device to this point. I know originally, we added some limiting checks to keep things simple, and that’s likely what you are running into. I’ll add a feature request to allow public and private in combination with both device and constant (I think those two make sense) for PGI 12.0.
