Hi to everybody,
I’m compiling the following codes:
1.main.f90
program main
implicit none
integer, parameter :: N=512
integer :: k,i
! loop
do k = 1, N
end do
! Do the same computation with CUDA.
! Fortran -> C -> CUDA ->C ->Fortran
call cudafunction(valore,N)
Results
print *, "valore=", valore[i][k]
end program main
2.Cuda_function.cu
#include <stdio>
#include <cuComplex>
#include "cuda.h"
/* Define CUDA kernel that fixes valore[i][k] = k */
__global__ void square_complex(int valore[512][512], int k, int N)
const int i = blockIdx.x*blockDim.x+threadIdx.x;
if( i<N )
valore[i][k] = k;
Fortran subroutine arguments are passed by references.
extern "C" void cudafunction_(int *valore, int *Np)
int block_size=4;
int *valore_d;
int N=*Np;
/* Allocate complex array on device */
cudaMalloc ((void **) &valore_d , sizeof(int)*N);
/* Copy array from host memory to device memory */
cudaMemcpy( valore_d, valore, sizeof(int)*N ,cudaMemcpyHostToDevice);
/* Compute execution configuration */
dim3 dimBlock(block_size);
dim3 dimGrid (N/dimBlock.x);
if( N % block_size != 0 ) dimGrid.x+=1;
/* Execute the kernel */
square_complex<<<dimGrid>>>(valore_d,Np);
/* Copy the result back */
cudaMemcpy(valore_d, sizeof(int)*N,cudaMemcpyDeviceToHost);
/* Free memory on the device */
cudaFree(valore_d);
return;
The compiling is in error.
The output of the compiling is:
Cuda_function.cu(45): error: argument of type “int " is incompatible with parameter of type "int ()[512]”
Cuda_function.cu(45): error: argument of type “int *” is incompatible with parameter of type “int”
Cuda_function.cu(45): error: too few arguments in function call
Cuda_function.cu(48): error: argument of type “unsigned long” is incompatible with parameter of type “const void *”
Cuda_function.cu(48): error: too few arguments in function call
5 errors detected in the compilation of “/tmp/tmpxft_00006dfd_00000000-4_Cuda_function.cpp1.ii”.
make: *** [Cuda_function.o] Error 2
Is there anybody that knows what is the problem?
silvio.
