CUDA fortran manual loop index with function call
Good morning,
I’m having a problem with some CUDA code where I set the starting value of a loop index using a function call. Here’s a condensed example:
attributes( global ) subroutine test_kernel()
  integer    :: i, i_max
#if DOES_NOT_WORK
  i = test_func()
#else
  i = 3
#endif
  i_max = 5
  outer: do while( i .lt. i_max )
     i = i + 1
  end do outer
end subroutine test_kernel
integer attributes( device ) function test_func()
  test_func = 3
end function test_func
Which if compiled with DOES_NOT_WORK set produces
PGF90-S-0000-Internal compiler error. size_of:bad dtype       0 (gpu.f90: 30)
PGF90-S-0000-Internal compiler error. size_of: bad dtype        0 (gpu.f90: 30)
PGF90-S-0000-Internal compiler error. unsupported datatype construct       0 (gpu.f90: 30)
  0 inform,   0 warnings,   3 severes, 0 fatal for test_kernel
/tmp/pgcudaforec0dmJYfd0xe.gpu(7): error: identifier "e15" is undefined
1 error detected in the compilation of "/tmp/pgnvd4d0dOfLN6YgQ.nv0".
PGF90-F-0000-Internal compiler error. pgnvd job exited with nonzero status code       0 (gpu.f90: 37)
PGF90/x86-64 Linux 10.9-0: compilation aborted
Any help with this is much appreciated.
-Martin
I wrapped your routine inside a MODULE
% more cuda_ex.CUF
MODULE foo
CONTAINS
integer :: i, i_max
#if DOES_NOT_WORK
i = test_func()
#else
i = 3
#endif
i_max = 5
i = i + 1
end do outer
test_func = 3
end MODULE foo
and it compiled without indicent with
pgf90 -c cuda_ex.CUF
and
pgf90 -c cuda_ex.CUF -Mcuda=cuda3.1
but not
pgf90 -c cuda_ex.CUF -Mcuda=cuda3.0
this had problems.
If you continue to have problems, look at the
output of your compile line with the added switch
-dryrun
if you find you are reading a ‘sitenvrc’ file, rename this file
to something like sitenvrc_bak so it is not read. We do not use this
anymore except for special diagnosis. You should only be using the
CUDA versions we install with 10.9, and not trying to use your
own installation. If you are using Nvidia CUDA, put their bin directories
after PGIs in you PATH.
regards,
dave
