cuda-gdb can be plugin in eclipse?
Hello!
I will study cuda(using CUDA SDK 4.0) on linux(Fedora 13).
But I have some problem.
I’m going to use eclipse for cuda programming.
Does cuda-gdb work in eclipse?
This would be very tricky cause you can’t have a active GUI when only having one GPU.
And most programmers will only have one graphic card at there machine.
To run eclipse you need a active GUI.
