Hi, I’m getting this error when trying to step into a kernel (mine) using Nsight. Similar problems regarding any of my kernels I try to debug. However, I can debug Sample code kernels just fine.
Details:
* RedHat Linux 7.5 on AWS p3.2xlarge (x86_64 w/ V100 GPU)
* Nsight Eclipse Edition v. 9.2.201806130420 (running Nsight on the server remotely from my Windows desktop via MobaXterm SSH X-windows tunneling.. Could this be the problem? )
* Running debugger via Nsight
* NVIDIA-SMI 396.44 Driver Version: 396.44 |
* Stepping through the program using Nsight debugger, trying to step into the kernel. (Note: this works on Sample code, e.g., NVIDIA_CUDA-9.2_Samples/6_Advanced/cdpLUDecomposition, just not on my kernel)
* CUDA V9.2.148
* NVIDIA (R) CUDA Debugger 9.2 release / GNU gdb (GDB) 7.12
* Program is compiled in Nsight using Separate Compilation, Compute Capability 7.0, -G, -g, -O0. The kernel-portion is compiled into an .so, and linked into a separate main() app. It runs just fine. I simply cannot step into or break on any kernels.
Thanks,
Jerry
