I’m trying to run some code through cuda-gdb and I get the following error:
fatal: The CUDA driver failed initialization. (error code = 28)
The code runs fine through a normal terminal, it is only through the debugger that I get this problem (program executes normally outside of the debugger). All code, no matter how trivial fails in this way. It fails regardless of which device I try to run on.
System specs:
OS: Ubuntu 11.04 64-bit
Driver: Linux 64-bit, 285.05.09 (Upgraded from 280.13 which has the same issue)
SDK version: 4.0.17
GPUs:
cuda device order:
0: Tesla C2050
1: GTX 295
2: GTX 295
3: GTX 460
4: Tesla C2050
Physically in the machine they are ordered as (from top to bottom):
Tesla
Tesla
GTX 460
GTX 295
There are 2 24" screens attached to the GTX 460 and another on the GTX 295 (no screens on either of the C2050s).
I can’t find any references to error code=28 in any of my searches, can anyone help?
Thanks,
Simon
