0x5f
May 26, 2011, 12:18pm
1
I’m trying to debug a simple CUDA application on a remote machine via ssh.
After I set the breakpoint, I try to run or step through the program and I receive the following error:
Error: Failed to read the valid lanes mask (dev=0, sm=0, wp=0, error=13).
What this error means ? How can I fix it ?
Thank You
Thank You
0x5f: Which GPU? What’s the toolkit version and driver you’re using? Can you also paste the application? Is the error intermittent or always reproducible? Thanks.
Also, try using the latest 4.0 toolkit, quite a few such bugs were fixed in the 4.0 release:
