NSight VS Code Edition: v2021.1.30130113
cuda-gdb version: 11.1/gdb8.3.1
container: nvcr.io/nvidia/deepstream:5.1-21.02-devel
When using the “NSight Visual Studio Code Edition” extension for VS Code, it seems that absolute paths are needed for any files passed at the command line or referenced by the application when using the cuda-gdb debugger. I encountered this while trying to step through a deepstream application example, which uses configuration file. I am guessing it is using the cuda-gdb installation location, but it would be nice to have the option to change working directory via “cwd” like in “cppdbg” so that relative paths can be used
It is also odd that you cannot enter “args” as an array like in “cppdbg”. You can only enter a single string like example configuration from launch.json below:
“name”: “CUDA C++: Launch”,
“type”: “cuda-gdb”,
“request”: “launch”,
“gdb”: “cuda-gdb”,
“program”: “/path/to/app/deepstream-app/deepstream-app”,
“args”: “-c /path/to/config/file/deepstream_app_config.txt”,
“stopAtEntry”: true,
“setupCommands”: [
“description”: “Enable pretty-printing for gdb”,
“text”: “-enable-pretty-printing”,
“ignoreFailures”: true
